Mines an 87 and the hazards stopped workin what number fuse is it?
take the lower tray off under the steering wheel and there shud be a big block underneath to the left with wires connected to it, squeeze it together and see if they work. i had this trouble with mine
try here (page 2): http://www.golfgtiforum.co.uk/index.php?topic=44637.0does sound like the hazard switch is at fault, which means you have to replace the whole indicator stalk. check the red/yel wire to pin 30 on the stalks gets permanent live though
