Author Topic: Dodo juice Spin Doctor  (Read 5417 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« on: 01 November 2010, 23:04 »
thinking to get this
what are peoples views on this device, im guesing nobody has used one seen as its new on the market??
http://www.monzacarcare.com/machine-polisher-g220-meguiars-buff-daddy-dodo-juice/dodo-juice-spin-doctor-rotary-machine-polisher/0/
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tech1889
  • Mk2 GTI FTW !!
Re: Dodo juice Spin Doctor
« Reply #1 on: 01 November 2010, 23:10 »
if its like the rest of dodo juice products it will be great.. i think a few people have tested it..
Offline F17BAD
« Reply #2 on: 01 November 2010, 23:12 »
yeah im a big fan of the brand. hence why the interest in this, think ill just buy it, but was wondering if anyone had actually used one.. :cool:
Offline Dan J
« Reply #3 on: 02 November 2010, 00:24 »
hi, they are very light and are smaller than a "standard" rotory, i mean standard very loosely as they are all slightly different in size and weight but the dodojuice spin doctor is roughly similar in size and weight to the festool rap 80 rotory which is for smaller fiddly bits of body work.
the spin doctor is a nice bit of kit and is nice and light which is good for someone moving up from a DA to further there machine polishing skills and for the price its a good one to get you started, id recomend using 135mm pads on it and not the 150mm pads as the 135s are alot easier to handle on the car and give you better feel for what you are doing,
also get yourself a few scrap panels(bonnets are better for there larger flatter area)to practice on, also find a course near to you and go along and watch a pro doing it so you can see the technique of it.
hope this helps.
Offline F17BAD
« Reply #4 on: 02 November 2010, 08:47 »
Cheers dude, sounds like a plan, and something i had considered too, dont wanna ruin my paint or anything  :undecided:
Offline Jimble
« Reply #5 on: 02 November 2010, 11:49 »
Is there any reason why Dodo juice don't do more products for use with a DA/rotary? Seems all they do is lime prime and a supernatural stick :huh:
Offline waxamomo
« Reply #6 on: 02 November 2010, 16:46 »
They now do a full range of pads and backing plates, they are all great BTW. I love the Supernatural backing plates.
I think they have probably got compounds on their list to produce at some point, but don't forget they are still a fairly new company and they are releasing new products all the time, the next batch of new products is due middle of this month  :wink:
Just to answer the OP's question, we have sold quite a few of the Spin Doctor's now and have had quite a few glowing reports without a single negative one  :smiley:
Offline F17BAD
« Reply #7 on: 02 November 2010, 17:09 »
cheers mate
do you stock them then, if so how much is your price
and what other stuff would i need ?
Offline Dan J
« Reply #8 on: 02 November 2010, 17:49 »
chris the supernatural backing plates are good and are pretty much the same as the liquid shine backing plate which i have and love using.
need for speed can be applied by machine with a finishing or finnessing pad producing good results.
« Last Edit: 02 November 2010, 17:51 by Purple Haze »
Offline waxamomo
« Reply #9 on: 02 November 2010, 17:53 »
Do you already have pads and polishes?
Here is the polishing section:
http://www.waxamomo.co.uk/productcart/pc/viewCategories.asp?idCategory=5
Let me know what you already have and i'll see what I can recommend  :smiley:
Chris
