Author Topic: gearbox interchange -ability ?  (Read 977 times)
Offline shikta000
« on: 31 October 2010, 13:54 »
to cut a long story short ... i've recently bought a gearbox from a seller on ebay, the add picture showed the gearbox in the donor car with a later type clutch cable connection to the box .... when i received the box my mechanic ( with 20 years experience of gti's) said that the box sent was an earlier type box which meant it needed an earlier type clutch cable connection ... my question is are the different clutch cable connections interchangeable with earlier and later type boxes .. oh and i have an '88 8v. cheers guys.
Re: gearbox interchange -ability ?
« Reply #1 on: 01 November 2010, 09:24 »
can fit either cable t either type of box. the only difference is the thin metal rod that holds the cable steady is different. this can be unbolted and swapped over. you want the early cable anyway, its cheaper and more reliable
Offline shikta000
« Reply #2 on: 01 November 2010, 18:28 »
thought it would be you rj with the answer ... ta
Offline jeremybarker
« Reply #3 on: 01 November 2010, 18:40 »
He's like the wise master, he fixed my car for me today too  :cool:
Making up for lost time
