Author Topic: Steamy windows!  (Read 2317 times)
Offline Deefadog
  • Mk2 16V (November 89)
Steamy windows!
« on: 03 February 2005, 18:19 »
Just when I thoght all my probs were solved :)
Lat 2 days I have noticed that when i put my blowers on hot all the windows in the car steam up, there must be water getting in from the coolent as it has not rained in over 8 days!
Is this the famous "Matrix explode"? as my water levels seem fine? or is this just the start to the full blown explosion? :)
Any ideas on where i should start to look for this?
Offline Deefadog
Re: Steamy windows!
« Reply #1 on: 04 February 2005, 08:07 »
Drove to work this morning with blower on screen setting and heat control on cold, no steam what so ever, as i got to work i turn the heat up to full and everything steamed up!
Think my matrix has gone :(
Any checks to confirm this or could it be something else?
Offline Gambit
Re: Steamy windows!
« Reply #2 on: 04 February 2005, 09:52 »
probably has gone if your blower blows out steam instead of hot air lol!
Offline Deefadog
Re: Steamy windows!
« Reply #3 on: 04 February 2005, 10:56 »
Is it just a case of replacing the matrix, gsf - ?30?, is there a repair for it? or just replacement.
Also is there something I can do tempory to stop it or disconnect it?
« Last Edit: 04 February 2005, 13:46 by deefadog »
Offline Gambit
Re: Steamy windows!
« Reply #4 on: 04 February 2005, 16:59 »
nah its just a straight swap job. but its a bit of a pain in the arse to get at. the Golf mag done a very good detailed article on changing it a year or so ago
mix
Re: Steamy windows!
« Reply #5 on: 04 February 2005, 17:14 »
When ever you think something like that, it'll all blow up in your face!! :wink:
I think my bro has the issue, i'll try find out for ya and send it to ya.
Offline Deefadog
Re: Steamy windows!
« Reply #6 on: 04 February 2005, 17:47 »
Cheers, guyz, found the 'how to' on club gti!
I am half way through, and boy it's alot of work, have to take half the car apart to change it :) at least I can give everything a good clean and sort the underdash wires out :)
And just for the record who ever invented those Bl**dy spring clips for the hoses should be shot!! Everyone send a fiver to the person who invented the jublie clips :)
Those clips have cost me hours off my life trying to get them off, and then dodging tem when they fly off : lol
I'll report back when it's done
Offline Mr Blue
Re: Steamy windows!
« Reply #7 on: 04 February 2005, 21:39 »
heard you can use the mk3 matrix thats alot stronger
Offline RSTRich
Re: Steamy windows!
« Reply #8 on: 08 February 2005, 10:03 »
I've got this problem too, except a bit different, Mine point blank refuses to blow hot air, at all, I've got the new matrix etc, but it ain't going in just yet, waiting for the conversion as the cars getting gutted anyway!!  So hopefully shouldn't be too difficult with car in pieces!
sober: very similar to being drunk, only a whole lot worse
Offline tinman
Re: Steamy windows!
« Reply #9 on: 08 February 2005, 11:01 »
its because the matrix has a tap that is stuck to off. the matrix only gets hot water when the tap is allowed to pump water through.
have exactly the same problem with my 827 at the moment.
