Author Topic: Sunroof Welding/New part?  (Read 5310 times)
Offline jonnypolish
  • t2871r needed :)
« on: 30 October 2010, 22:36 »
With my tax rebate coming within the next 14 days i'm back on the hunt for a Mk1 :afro:
Seen an ABSOLUTE Beaut! and im not sharing a link since i dont want anyone to pinch it :D
Just wondering how much it would be to get the sunroof completly welded over (As in deleting it)
Or
How much an aftermarket/OEM part would be to replace it since the car im looking at comes with just a hole. LOL :D
I look forward to your responses :)
Jon
 MK2 VR y0!
Offline SoundillusioN
Re: Sunroof Welding/New part?
« Reply #1 on: 30 October 2010, 23:25 »
You haven't stated if this is a factory fit you wish to remove or a hole left by an after market sunroof?  Big difference.  I dont think there is a part that covers this, would need to be frabricated or a section cut from a scrappers roof skin, however there is quite a bit to think about regarding the inside...  If this is factory fit then everything involved for the mechanism would need to be stripped out and you would need a new roof lining.  If this is just a hole from an after market job then you would still need a new lining.
Offline jonnypolish
  • t2871r needed :)
« Reply #2 on: 30 October 2010, 23:50 »
Gayness :( was an aftermarket jobby that was taken out!
Guy ran this one for his daily so switched all the best parts out for his '79!
I'm sure i can run the same aftermarket part that he had in before if i can source another?
Would rather have it all welded up though :( don't like sunroofs. they leak!
 MK2 VR y0!
« Reply #3 on: 30 October 2010, 23:53 »
With a major amount of work I have seen roof skins changed by unpicking spot welds.
Offline shepgti
« Reply #4 on: 31 October 2010, 00:58 »
i have seen whole roofs chopped from tin tops to replace non factory sun roof holes. alot of work however
« Reply #5 on: 31 October 2010, 01:10 »
Indeed.... chop the skin and get yourself one of these...
Click!
and on a serious note I think your sunroof idea is probably your best and cheapest option.  I wouldn't worry too much about getting the exact same one, you have a hole already so get what you want and trim hole to fit.  do a good job of it/look after it and it wont leak.
Shaun
Offline jonnypolish
  • t2871r needed :)
« Reply #6 on: 31 October 2010, 09:28 »
That Carbon skin look spot on! It appears to be on that AWD Mk1 dragster?
Hmmmmm i'm a pervert when it comes to things being smooth though :( May have to run around a few bodyshops and see what people can do!
If not its aftermarket sunroof ahoy! Then Black it out or something!
 MK2 VR y0!
« Reply #7 on: 01 November 2010, 17:29 »
Yeah its the AK Bodycraft MK1 that was at Inters this year
700bhp 1.8T, 0-60mph in 2.4 and top speed of 180mph.  It can beat the Bugatti in a quarter-mile sprint.
Offline jonnypolish
  • t2871r needed :)
« Reply #8 on: 01 November 2010, 17:55 »
Saw it at pod last time i was there! Chewed up pretty much all that went up against it!
Only guy that even nearly kept up was in a syncro Mk2, not sure what engine!
But that Mk1 was running 10's easy!!
 MK2 VR y0!
Offline fishnchipsx2
« Reply #9 on: 02 November 2010, 12:09 »
Cheap option is to rivet some ali plate over the hole  :tongue:
