as above gaskets are the same, it bolts right up. wont work tho as will result in low compression. ok for boost but still have to change the timing belt sprockets, intermediate shafdt, oil pump and dizzy blanking plate/oil pump upper bearing assy. may still need to cut the piston head a little to avoid valve clash, not 100% on that.
basically, short answer is either way you try it, no.
