Author Topic: Battery Drain  (Read 6252 times)
Offline Jimp
Re: Battery Drain
« Reply #10 on: 01 January 2011, 23:09 »
You should be fine, the change was in late 06 early 07 I think.
Not low enough mk5
Not on the road enough mk3
Offline sprout99
Re: Battery Drain
« Reply #11 on: 04 January 2011, 20:52 »
what needs to coded different?
our car has MFD2 fitted but i think it was retrofit as the GPS aerial was sat on dash top.
i have noticed the radio makes bizarre noises like a cd searching even when unit is off.
it's sporadic.
battery not gone flat while we've owned it. TBH the battery is 72AH !!! is that normal ??
Ian
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline pluslyn
Re: Battery Drain
« Reply #12 on: 07 January 2011, 12:01 »
Have you a CD player, if so then load a CD and this will stop it searching. (Just leave it in).
Offline sprout99
Re: Battery Drain
« Reply #13 on: 07 January 2011, 12:15 »
i had noticed that with no DVD inserted it's quiet
it seems to do it when changing diretion while driving
bizarre.
Oak green mk2
V50 D5 Sportwagon
