Author Topic: mk3 gti 8v AGG engine code (oil on spark plug THREADS)  (Read 2008 times)
Offline sharki786
  • GOT BOOST??
i was just looking over the engine untill i noticed some oil comming from the left hand side spark plug, after chaging them all i noticed that all of the THREADS of the spark plugs had oil on them, someone said its the steam valve seals? is that true? as the engine was rebuild in feb this year. just need comfirmation thats all. the 1st spark plug (left hand side) was the worse.
all help much appreciated
thank you
*****MK3 Anniversary*****
*****MK4 GTI T*****
Re: mk3 gti 8v AGG engine code (oil on spark plug THREADS)
« Reply #1 on: 29 October 2010, 15:07 »
more likely you just have a rocker cover leak and its worked its way down the threads. if you have oil leaking up the threads from inside the head you have greater issues than stem seals  :grin:
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 29 October 2010, 15:12 »
no leak from rocker cover. the spark plugs where abit loose didnt have to use any energy to undo them either. what issue can that be then? il just take it back to the bloke and get him to do a PROPER rebuild!
*****MK4 GTI T*****
« Reply #3 on: 29 October 2010, 15:23 »
if loose then that could explain it, clean up threads and the holes and nip em up again (dont use uber force, only aluminium threads!) just nip up.  keep an eye on it :)
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 29 October 2010, 19:22 »
but what i dont understand is that where did that oil come form?
*****MK4 GTI T*****
Offline AudiA8Quattro
« Reply #5 on: 31 October 2010, 19:49 »
Use a torque wrench, then you know it is tight enough.
