Author Topic: VAG COM????  (Read 2191 times)
Offline kevjenkins
  • VW ITS A RELIGION
VAG COM????
« on: 29 October 2010, 09:48 »
I have just got my vag com lead and software disc offa ebay and it has loaded fine i have gone into setting to change the port and it still dont reconise the cable any ideas please
Re: VAG COM????
« Reply #1 on: 29 October 2010, 10:00 »
go into device manager and check the virtual com port number. if its higher than 4 you'll have to go into the properties and change it for a lower number, and if the lower numbers are taken you'll have to change one of the other ports to a higher number first to clear it, then change the vagcom cable to the lower number.  does that make any sence at all?
Offline kevjenkins
  • VW ITS A RELIGION
Re: VAG COM????
« Reply #2 on: 30 October 2010, 10:19 »
Now i got it to reconise the cable (com 3) it will not reconise the fookin car when conected???
Offline topher
  • Administrator
  • fully functioning
Re: VAG COM????
« Reply #3 on: 30 October 2010, 10:26 »
what car is it? the ones floating around ebay at the moment often struggle with pre 2001 cars
Offline kevjenkins
  • VW ITS A RELIGION
Re: VAG COM????
« Reply #4 on: 30 October 2010, 11:23 »
W REG 2000 V6 4 motion!
Offline kevjenkins
  • VW ITS A RELIGION
Re: VAG COM????
« Reply #5 on: 30 October 2010, 11:24 »
If this is the case where do i get the one that will work ????????
Offline Cunning stunT
Re: VAG COM????
« Reply #6 on: 31 October 2010, 20:57 »
ross tech...  :wink:
Silver 3 Door 1.8T.... R-Tech map, Forge d.v, pipercross Venom Cai, J valve, silicone tip.....
Re: VAG COM????
« Reply #7 on: 01 November 2010, 09:55 »
i take it you have the ingition switched on when you're trying it, and the led on the port lights up when plugged in?
Offline sharki786
  • GOT BOOST??
Re: VAG COM????
« Reply #8 on: 01 November 2010, 16:14 »
you prob got the tenner one, you need it with the interface built in, mate had same prob
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline kevjenkins
  • VW ITS A RELIGION
Re: VAG COM????
« Reply #9 on: 01 November 2010, 18:03 »
SSSSSSSSSOOOOOOOOOOOO
how much do i spend??????
they range from 10 to 249????? on ebay
