Author Topic: Mk2 8V strange idle problem  (Read 1739 times)
Offline jammy_c
« on: 03 February 2005, 11:51 »
Hi all,
I've got an "88" mk2 8v Gti campaign, and recently i've been having problems with the idle speed, it will sit at 1000rpm, then slowly climb to 2500rpm or more, hold it there for about 10 seconds, then drop again.
I thought at first it was a cold-start system, but it does it all the time now, even when the engine has been running for nearly an hour, and is hot.
I assumed it must b a problem with the idle control valve, so i removed it, gave it a good squirt with carb-cleaner, and put it back on, but still no use.
Any ideas guys? :huh:
James - MK2 8V GTI Oak Green Campaign
Offline Gambit
Re: Mk2 8V strange idle problem
« Reply #1 on: 03 February 2005, 17:28 »
try resetting the ECU. u disconnect the blue water temp sender then rev the engine 3 times to over 3k - this resets it
Offline jammy_c
« Reply #2 on: 03 February 2005, 21:08 »
Quality, i'll try that.
Thanx!
 :wink:
Offline nyek7
« Reply #3 on: 04 September 2009, 21:56 »
hay just woundered if this worked?? :nerd: a got the same prob with my 88 mk2 just got the car an dont no much about zee germans lol  :grin: :grin:
Offline Ben Lessani
« Reply #4 on: 05 September 2009, 11:01 »
Check the last post date ;)
« Reply #5 on: 07 September 2009, 09:38 »
this doesnt reset the ecu at all, it just puts it into setup mode so you can adjust the idle/co. see my digifant tuning guide in the mk2 how2 section :)
