Author Topic: Cruise Control  (Read 15894 times)
Offline evo1986
Cruise Control
« on: 28 October 2010, 09:39 »
Aftermarket cruise control for 2010 Passat CC, Eos and Scirocco, and 2011 Golf
1038-10
Technical difficulties mean we are currently unable to provide a release date for aftermarket cruise control for 2010 model year Passat CC, Scirocco and Eos, and 2011 Golf models. Please ensure customers are advised accordingly.
The Factory is committed to developing a solution, and we’ll update you with more information about this as soon as we have it.
Be warned if you are thinking of not ordering it from factory and then retro fitting for cheaper.........
Sales Manager
WhatsApp: 07389107119
Offline evo1986
Re: Cruise Control
« Reply #1 on: 28 October 2010, 09:46 »
Ooops didnt read further down.........
Sales Manager
Offline woodman
Re: Cruise Control
« Reply #2 on: 28 October 2010, 11:57 »
Dealer fitted one to my car last week. Claims that it was a problem because VW wouldn't release a code initially, but they did and it works fine. Not sure what the problem is.
Offline Movi
Re: Cruise Control
« Reply #3 on: 28 October 2010, 12:12 »
Hi Woodman is yours a 2011 golf ? which dealer fitted and got it working for you?
Keen to get mine done as soon as possible
Movi
(MY08) ED30 CW 3DR (Sold) - (MY11) MK6 GTD CW 3DR DSG - Its Here :) MK7 R LB 3DR DSG
Offline evo1986
Re: Cruise Control
« Reply #4 on: 28 October 2010, 12:32 »
Cant be a 2011 my car.
Sales Manager
Offline Keithuk
Re: Cruise Control
« Reply #5 on: 28 October 2010, 17:29 »
Well you could fit your own if you have the VAG-COM. All you need is the switch
Criuse control system for vehicles with multi function indicator 06/01/2010>> 1K0 054 690 B - £57
You just change the switch and programme the ecu to accept it.
VW want £220 to fit it as an option on a new car so it will cost a bit more fitting it afterwards. You will see them available on eBay.  :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Hartside
Re: Cruise Control
« Reply #6 on: 28 October 2010, 17:45 »
Current accessories brochure shows CC as a £162.50 dealer fit. Evo1986 is saying 2011 MY cars cannot have the retrofit at the moment, but VW is working on a solution.
Could never work out why it was a higher priced factory option  :undecided:
Carbon Grey 5dr GTI
Offline woodman
Re: Cruise Control
« Reply #7 on: 28 October 2010, 21:33 »
EVO. Collected my car last wedneday, vw main dealer uk mainland, MY 11 it has rear led lights and says my11 on invoice, so must be. Cruise is dealer retrofit, said they had a problem re code, but all sorted  when collected, works perfectly, appears on high level display, so can be done.
 :rolleyes:
Offline Keithuk
Re: Cruise Control
« Reply #8 on: 28 October 2010, 21:41 »
I think you'll find its MY2011. So what model do you have?  :wink:
Offline Movi
Re: Cruise Control
« Reply #9 on: 28 October 2010, 22:58 »
 :rolleyes:
Good News  :smiley:
Which Dealer sorted the re-code for you?
My local dealer just keeps on quoting 1038-10 bulletin.  :rolleyes:
Movi
