Author Topic: 130. Water/meth injectors ?  (Read 6569 times)
Offline josh_419
  • A hammer - The answer to everything
« on: 28 October 2010, 00:57 »
Recently had my car mapped and he said things to do would be, panel filter, zaust and water meth injectors, can anyone advise me on these ?
i.e.
somewhere to buy them
gains
how difficult to fit
GT TDI 130 - TT alloys, HID's, Lowered 35mm, ReMap (178bhp) + ridiculous torque. Build Thread
GTI 1.8 20v - For sale £2000
Offline Agreeable Slick
  • Unit
Re: 130. Water/meth injectors ?
« Reply #1 on: 28 October 2010, 08:30 »
Who did you go to for the advice for water/meth injectors?
The only reason for having water/meth injectors is to lower the temps on the engine/intake paths so you can crank up the boost, and have slightly more advanced timing plots.
The power boost is negligable on them from what I've read, and it will not give you a better set up than a FMIC would. However, getting them both working in parallel would yield some benefits.
What you need to remember is that a CI engine is a heat engine, not like petrol where really cold air = good.
Basically, unless you are going to track the car, or pull big loads up steep inclines then water/meth injectors are a little overkill.
FMIC it first, and you will not have the issues of worrying about constant maintenance and whether your turbo is about to go pop, or whether the manifold is about to make it's own warped shape up.
Offline josh_419
« Reply #2 on: 28 October 2010, 15:02 »
Okay thanks for that. The bloke that mapped it told me these things. He was probably just being general or something.
FMIC ? could you explain ?
  • Unit
« Reply #3 on: 28 October 2010, 15:04 »
Front Mounted InterCooler. :smiley:
Offline josh_419
« Reply #4 on: 28 October 2010, 15:05 »
of course, how silly of me.
Actually already looked at this. thought it was very cheap so could you advise me ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200535849778&ssPageName=STRK:MEWAX:IT#ht_829wt_905
  • Unit
« Reply #5 on: 28 October 2010, 15:08 »
Honestly I don't know which are the best kits for FMIC's so the best people to talk to would be the guys in the remap section. If you put a topic in there then one of them would be able to advise better than I would.
Although I would have a go on the search function first and see what that throws up.
Offline josh_419
« Reply #6 on: 28 October 2010, 15:09 »
Alright bud. Thanks for your help
Offline Rhyso
« Reply #7 on: 28 October 2010, 16:04 »
Only proper FMIC kit for the 130 is sold by Forge
As Slick has already said water / meth injection really isn't worth it
Bloke running a 260bhp ARL engine even removed it from his setup as he found it to be of little benefit
Offline josh_419
« Reply #8 on: 28 October 2010, 16:39 »
So all other FMIC's aren't worth looking at ?
Say if i do get the FMIC is this all i would need to be able to support a larger turbo, if so, is there one ?
Offline Rhyso
« Reply #9 on: 28 October 2010, 16:42 »
Forge are the only people who make a fit and forget kit.  Only other way you'll get an FMIC is buying the core and making up the pipework yourself
You can fit the 150 turbo and get that uprated(hybrid).  Max you'll see out of that will be 220bhp
To go beyond that you'll need new injectors and a bigger turbo.  A few people have started fitting the GT2260 from the 3.0 TDI engine found in the latest Audi's
With a proper setup, injectors, FMIC there are a few now running over 255bhp
