Author Topic: rough running,,please help  (Read 2982 times)
Offline tenere
Re: rotor arm
« Reply #10 on: 28 October 2010, 20:33 »
Thanks for the pointers. :smiley:
if i blast it ,it will rev out,but just wont cruise at mid revs,,sort of holding back and jerking.
starts as normal,slightly rough tick over,,i can just about get some where at 30 mph..so using my bike for transport at moment,,and its a bit cold !!
Offline tenere
Re: rough running,,,please help
« Reply #11 on: 16 November 2010, 21:34 »
Hi,can anybody give any help/pointers (1997 2l 16v abf)
slightly rough idle...(in neutral)holding revs about 2.5rpm feels slightly lumpy.
when you the drive car it kangeroos ,jerks at about 2.5k to 3k rpm.
i have changed plugs,rotor arm,dis cap,plug leads.the vacuum pipes i could see,cleaned throttle body,
stripped airbox to check for nests.
next i will possibly change fuel filter
i have read on here to check ecu relay and fuel pump relay,,where are these,,do they have a number.
is it true by disconnecting the battery the ecu resets itself ??
any advice would be much appreciated,thank you in advance
« Last Edit: 16 November 2010, 23:33 by tenere »
Offline javalin
Re: rough running,,please help
« Reply #12 on: 17 November 2010, 14:02 »
ECU relay is no.30 and Fuel pump is no.167.   Might be worth having a compression test done to rule out any "physical" problems if you see what I mean (head gasket, valve seats etc).
I would check the grounds to the ECU, body, engine etc.  Any smoke from the exhaust?  Does it get better hot or cold?
Would also consider changing these in this order - and one by one (to see what fixes it):
-> coolant temp sensor
-> fuel filter
-> lamda (oxygen) sensor.  Does it have a MAF (airflow) sensor on the air intake?
http://javalins.wordpress.com/vw-golf-mk3/troubleshooting-common-fixes/
See how you get on and let us know,
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline tenere
« Reply #13 on: 17 November 2010, 19:08 »
hi James,,many thanks for the reply.I spoke to an old friend today who works at VW HQ and used to be a VW mechanic and he suggested the water temp sensor (which you suggested too).
He described the location and that it is held in by a "horse shoe" type clip. Unfortunately i cannot find it.On the right side of the block there is a water pipe with what looks like round bung held in by a horse shoe clip,but it is flat on top and no wires attached.
Where is the water temp sensor located ??
i phoned up dealer and they have sensor in stock at £28 ,does this sound right.
Thanks again for any help given
Offline javalin
« Reply #14 on: 17 November 2010, 19:12 »
yup £28 is about right.  What engine is it again?
have a look @ http://www.golfgtiforum.co.uk/index.php?topic=101400.0
Offline tenere
« Reply #15 on: 17 November 2010, 20:54 »
hi james..
my car is a 1997  Golf GTI 2.0 litre 16 valve (sticker on cambelt cover indicates its an ABF)
that shows an 8 valve engine so things are in different places.
still cant find the temp sensor
thanks
Offline javalin
« Reply #16 on: 17 November 2010, 21:12 »
oh, ok I *think* that the 16v sensor is on the right hand side of the block.
Anybody with a 16v want to help a bit here???
J
Offline Leon27
« Reply #17 on: 17 November 2010, 21:58 »
You described that and thats where I'd say it was:
http://picasaweb.google.com/kandpperformance/KP#5202641412355751298
I had a similar issue in which everyone gave great pointers:
http://www.golfgtiforum.co.uk/index.php?topic=152789.0
Out of interest have you tried the new relay 30 and 167? Worth doing if it hasn't been done
Offline tenere
« Reply #18 on: 18 November 2010, 10:00 »
Hi,,looked at that photo,,that is where mine has a blank.the blank is a proper thing and has vw markings on it.
i assume on 1997 abf  vw decided to relocate temp sensor
by the way the temp gauge on my car has always performed normally (5 years)
There is a brass thing screwed into battery side of radiator (the wiring is linked to fan ?)
There are some sensers directly above the oil filter ?
Thanks leon/james
Offline javalin
« Reply #19 on: 18 November 2010, 10:12 »
thats the fan switch
probably oil temp/pressure sensors
indeed.  these do fail occasionally.  There are also two sensors in the one block so possibly the dash has been ok, but its the ECU one thats gone wibble.
Perhaps you could post a photo of yours?  Confused.
James
