Author Topic: Fuel Filter for GTD  (Read 12105 times)
Offline JC
  • Back in the North.
Re: Fuel Filter for GTD
« Reply #20 on: 27 October 2010, 16:12 »
your giving spannering advice to a spanner who put the green nozzle  into his dark pump  machine  :shocked: :lipsrsealed:
Whats the worst that could happen ?
 :grin:
I new Chuff would be along  :laugh: :laugh:
got invited  :grin: :laugh:
do you drink doctor pepper.
bring it to me, i will do it for ya  :rolleyes:
Offline Steve30
  • Ed30 .
« Reply #21 on: 27 October 2010, 16:14 »
^^^^^  :laugh: :laugh: :laugh:
Tiguan quicker than the Golf
Offline Agreeable Slick
  • Unit
« Reply #22 on: 27 October 2010, 16:16 »
From that pic I reckon if you unclip the hoses from their mounts further back you should have enough slack/wiggle room to not have to take them off the top of the filter.
nick
I would be suprised, they are only routers/pipe tidies, not actual mounts. Plus one of the pipes is going to the pump under the engine cover.
Offline Horney
« Reply #23 on: 27 October 2010, 16:22 »
Well he can give it a go and if it isn't enough, whip the pipes off.
Nick
  • Unit
« Reply #24 on: 27 October 2010, 16:23 »
Indeed.
Offline JC
« Reply #25 on: 27 October 2010, 16:30 »
or just pay to have it done - he can afford a mk6 after all  :rolleyes:
 :lipsrsealed:
Offline Steve30
  • Ed30 .
« Reply #26 on: 27 October 2010, 16:34 »
 :lipsrsealed:
Indeed i do Chuff but was told its a 5 min job  :grin:
Offline mike.
« Reply #27 on: 27 October 2010, 18:19 »
Here is the workshop procedure if that helps  :smiley:
Remove engine cover panel
Removing:
Caution
Do NOT pull fuel hoses off fuel filter cover and do NOT lever at connection. Otherwise, leaks will occur and the upper part of the fuel filter can be damaged.
Ensure that no diesel fuel contacts other components in the engine compartment. Clean immediately, if necessary.
Carry out the following procedure:
–   Unscrew all bolts -arrows- from upper part of fuel filter and remove upper part of fuel filter.
If the upper part of fuel filter is stuck, loosen as follows:
The upper part of the fuel filter can be raised at assembly groove -arrow A- using angled screwdriver -VAS 6543-.
The assembly groove can be of different size, depending on the type of upper part.
Insert appropriate side of angled screwdriver -VAS 6543- in assembly groove -arrow A- and turn angled screwdriver -VAS 6543-.
Then the upper part of the fuel filter is raised.
Take filter -3- out of lower part of fuel filter.
Remove old seal -2- from upper part of fuel filter -1- by levering seal out of respective groove -arrow-.
Caution
Remove all diesel, dirt and water residues from lower part of fuel filter
Installing:
–   Insert new filter into lower part of fuel filter.
–   Moisten new seal -1- lightly with diesel fuel and insert into upper part of fuel filter -arrows-.
–   Place upper part of fuel filter with seal properly onto lower part of fuel filter, press on firmly and evenly until the upper part of fuel filter is correctly seated.
  Caution
Do NOT tighten bolts for upper part, before it is correctly seated onto lower part.
–   Screw all bolts into lower part of fuel filter and tighten hand-tight.
–   Then tighten bolts to 5 Nm according to sequence shown in illustration -arrows-.
Caution
This procedure prevents the seal from being damaged.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Steve30
  • Ed30 .
« Reply #28 on: 27 October 2010, 22:08 »
Excellent post mike and thanks to the others for there info brilliant Steve :cool:
Offline Rhyso
« Reply #29 on: 28 October 2010, 08:24 »
Have now created a how-to and put it into the maintenance section for future reference
http://www.golfgtiforum.co.uk/index.php?topic=170771.0
Nice one mike. :afro:
