Author Topic: Fuel Filter for GTD  (Read 12095 times)
Offline Steve30
  • Ed30 .
Re: Fuel Filter for GTD
« Reply #10 on: 27 October 2010, 15:45 »
here you go guys
Tiguan quicker than the Golf
Offline Horney
« Reply #11 on: 27 October 2010, 15:49 »
Yeah easy.
Mark em up so you remember which one goes where. Open the clip with pliers/mole grips (Squeeze the raised bits towards each other), wiggle it up the pipe and let go. Now you can pull the pipe off (Put some rag underneath to catch any spillage).
Refitting is the reverse of removal.
Nick
Offline Agreeable Slick
  • Unit
« Reply #12 on: 27 October 2010, 15:49 »
That's the one, bottom left, 4 hoses. In theory you should be able to just undo the screws on the top and then move the lot out the way. Replace the paper element and put it all back. However, it would probably be easier to pop the hoses off too, they are easily released little spring clips.
Once it's all back together, as Horne said, turn the engine over, it won't fire immediately as the filter will need to fill, oh and it might be worth getting some millers diesel additive as well, just to give it that little extra clean through the bits you cannot reach.
Offline Steve30
  • Ed30 .
« Reply #13 on: 27 October 2010, 15:54 »
So thats the 5 screws on top ? Can I not just leave the pipes alone and just take out the screws? Thanks chaps
  • Unit
« Reply #14 on: 27 October 2010, 16:03 »
Aye, those ones.
the problem you might find you have if you don't release the pipes is that it will drag the filter out at an angle too shallow to allow you remove it properly and it will get wedged. Hence my comment of unclipping will be more simple.
Oh and as you filled it with petrol make sure you get a new O ring for it, and whilst you are there, you might as well just check to make sure the water reservior at the bottom is nice and clean.
Offline Horney
« Reply #15 on: 27 October 2010, 16:04 »
Ah. I'm blind. Didn't even notice the screws.
Have you got the raplcement filter already and is it just a paper element? If so then you should just be able to open it up by unding the screws and swapping the filter elelement inside over. On mine you had to replace the whole metal unit.
Nick
Offline Steve30
  • Ed30 .
« Reply #16 on: 27 October 2010, 16:05 »
 this maybe a better picture can see it more clear on top?
« Last Edit: 27 October 2010, 16:08 by Steve30 »
Offline JC
  • Back in the North.
« Reply #17 on: 27 October 2010, 16:07 »
your giving spannering advice to a spanner who put the green nozzle  into his dark pump  machine  :shocked: :lipsrsealed:
Whats the worst that could happen ?
 :grin:
Offline Horney
« Reply #18 on: 27 October 2010, 16:09 »
From that pic I reckon if you unclip the hoses from their mounts further back you should have enough slack/wiggle room to not have to take them off the top of the filter.
nick
Offline Steve30
  • Ed30 .
« Reply #19 on: 27 October 2010, 16:09 »
 :grin:
I new Chuff would be along  :laugh: :laugh:
