Author Topic: Water getting inside the doors?  (Read 2153 times)
Offline rgb
« on: 25 October 2010, 22:42 »
A beautiful new car has arrived - saddow blue with Monza Shaddows - pics soon when I can take some decent ones.
One puzzle though. If its rained (or I've been washing it), when I open the doors there's a dribble of water that seems to run out from the bottom of the frame. Is this normal?  Seems like water must be running down the glass and into the door.  I guess it could be water trapped in the seal at the bottom
of the door frame, but it seems to come from the drainage hole at the bottom of the door.  All the doors seems the same.
I should add that the car is parked on a slope, so perhaps this has something to do with it.
Anyone else noticed this?  Wondering if I should take it back to the dealer?
thanks for advice!
Offline p3asa
Re: Water getting inside the doors?
« Reply #1 on: 25 October 2010, 22:52 »
No seems to be perfectly normal.
I've read about a few folk commenting on this.
My car sits on a level drive but if it rains and I open the door, the water doesn't half pour out. Its as if the doors being shut has prevented the water from escaping.
Offline Goofen
« Reply #2 on: 26 October 2010, 06:43 »
It is like a dog...car needs to lift it's leg to make a wee!
Offline gibby
« Reply #3 on: 26 October 2010, 09:54 »
I've got a 59 plate BMW and that does exactly the same. The seals on the door at the bottom of the windows are not water tight, so rain goes down into the door, then when you open it the water drops out of the drain holes. It's certainly not the best way to go about it, but I guess there's not much choice otherwise it's a problem that would have been solved by now. Make sure you open all the doors after it's rained so that the water doesn't sit in the bottom of the doors longer than necessary.
......now officially dubless.
Offline Keithuk
« Reply #4 on: 26 October 2010, 12:24 »
when I open the doors there's a dribble of water that seems to run out from the bottom of the frame. Is this normal?  Seems like water must be running down the glass and into the door.  I guess it could be water trapped in the seal at the bottom of the door frame, but it seems to come from the drainage hole at the bottom of the door.
Yes this is normal on mk6 Golfs even on Shadow Blue models this is because of the shape of the lower door seal they fit which retains water until the door it opened. I believe it can be as much as a litre when you open the the door, this has been commented on may  VW Golf threads its just a design fault.  :wink:
Oh I forgot to say. I'm told that VW modified these seals because customers complained of wind noise from the door and this was supposed to have cure this.
« Last Edit: 26 October 2010, 12:38 by Keithuk »
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline rgb
« Reply #5 on: 26 October 2010, 21:55 »
Phew! Seems odd to let the water run down the inside of the door like that - presumably they're confident it's not going to rust!
Offline squirrelGTi
« Reply #6 on: 27 October 2010, 08:35 »
Yep same for me. Very annoying!
Gone GTi | 3dr | Manual | Carbon Grey | Xenons | Monza 18's | RCD 510 |Rear Camera | Winter Pack.
Offline MAW73
  • Used to like Golfs :-)
« Reply #7 on: 27 October 2010, 09:11 »
I can't say I've noticed that before. I wondered why there were a couple of paddles in my boot when I picked my car up  :grin:
« Last Edit: 27 October 2010, 13:05 by MAW73 »
2014 BMW F20 M135i, Auto
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #8 on: 27 October 2010, 12:26 »
This is normal. Most cars do this.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
