Author Topic: BRAKING rocks in the hot sun  (Read 1210 times)
Offline theclash
« on: 25 October 2010, 22:10 »
front brake  caliper is sticking dust cover as perished so i carnt decide do i get a seal repair kit or do i buy a secondhand caliper off ebay? been told the front calipers are the same as the mk3 does anyone know if this is true. car is 92 8 valve
Offline Mitching
Re: BRAKING rocks in the hot sun
« Reply #1 on: 25 October 2010, 23:09 »
I like what you did there  :wink:
But sorry, can't help  :embarassed:
« Reply #2 on: 25 October 2010, 23:30 »
Better to fit a s/h caliper to be honest.
« Reply #3 on: 26 October 2010, 11:14 »
if it has 239mm brakes the low end mk3 4 stud have same calipers as mk2, VWII. but check before you remove the later ones may use a different brake flexi fitting on the caliper. I know the ones on our seat ibiza are VWII but use a banjo bolt rather than screw in fitting
Offline theclash
« Reply #4 on: 26 October 2010, 19:51 »
ok cheers guys   gonna try a repair kit theyve got them in at local vw 9 pound odd i think.   if i balls that up its 2nd hand caliper time  :grin:
