Author Topic: Does my Arse look big in this?  (Read 1713 times)
Offline LPG'd Oakie
  • Haha...I own one now!!!...And it works...ish
« on: 02 February 2005, 00:01 »
Due to the huge LPG tank in my boot the arse end has become deciedly saggy, looking like its on its original springs again!
So Guys Gall and everyone else...How do I go about getting the lardy arse end back to its orginal stance?
its a 16v so perhaps....8v springs for the extra 35mm?, those rubber inserts for towing?, Coilovers
All ideas welcome!
Offline Dizzie
  • Make friends with your fast
Re: Does my Arse look big in this?
« Reply #1 on: 02 February 2005, 08:07 »
lower the front to match  :grin:
Mk4 Golf 150PD
Judderi
« Reply #2 on: 02 February 2005, 08:09 »
Coilovers everytime if ya can afford them.
Offline Gambit
« Reply #3 on: 02 February 2005, 12:50 »
8v springs wil onlyl give you an extra 15mm
think your getting confused, the 16v sits 15mm lower than an 8v which sit 20mm lower than standard
yep coilovers is the only way you be able to set the height correctly, either that or stiffer springs on the rear
Offline LPG'd Oakie
« Reply #4 on: 02 February 2005, 13:26 »
Cheers Gambit, I thought the 8v sta the same as the driver, and the 16v was 35mm lower than those!
Anyone got any coil overs going cheap?
Judderi
« Reply #5 on: 02 February 2005, 13:44 »
Good luck! Did you get your lpg sorted in the end then?
Offline LPG'd Oakie
« Reply #6 on: 03 February 2005, 13:46 »
Should be sorted tomorrow, but the suspension is becoming a problem, as I nearly took my Back box off the other day!
Judderi
« Reply #7 on: 03 February 2005, 15:30 »
Welcome to the world of modified cars!
Offline LPG'd Oakie
« Reply #8 on: 03 February 2005, 22:28 »
I never had a problem with the last one, it wasn't about dropping it 1 or 2", it was about raising it 2 or 4"! hehe. Currently sits 4.5" higher on the body and 12" overall.
Still, this one handles a little better!
Judderi
« Reply #9 on: 04 February 2005, 09:37 »
What you want it higher!?!  :laugh:
We all want lower!
