Author Topic: drive shafts  (Read 3502 times)
Re: drive shafts
« Reply #10 on: 04 November 2010, 08:56 »
Might be wrong but were the later ones not bigger output flanges on the gearbox.  :undecided:
I think you're confusing the sub-GTI vehicles where they use 90mm CVs, not the 100mm CVs of the GTI/16V
Yep I was, thanks for clearing it up, I knew some were 90mm.
Re: drive shafts
« Reply #11 on: 08 November 2010, 09:35 »
1.6 and lower use 90mm flanges, 1.8 gti/carby/16v use 100mm flanges
Offline Diamond Hell
  • Opinions я Us
Re: drive shafts
« Reply #12 on: 08 November 2010, 14:17 »
This is balls.
Lower than GTI = 90mm flanges.
Syncro is 1.8 and that's on 90mm flanges.
What is a 'carby'?
Re: drive shafts
« Reply #13 on: 09 November 2010, 12:03 »
Looks like we are both right!
re-looking at etka early 1.8 carbed MK2 2WD and syncro were indeed 90mm, chassis break was up to 1G-K-990 000 which is around late 89 to 90. my mistake was just checking 1990 MK2 in etka
carby = carburettor equipped MK2 if you want to be captain pedantic
edit: well, technically we were both wrong and Wayne was right :grin:
« Last Edit: 09 November 2010, 12:38 by rubjonny »
