The garage
haunted mk3
Topic: haunted mk3 (Read 2183 times)
nate valve
haunted mk3
22 October 2010, 16:04 »
my mk3 gti every time i put my foot on the break it uses the rear indicator lights instead of the break light, if im indicating and break, it stops the indicators!!
wtf is going on???
f**k the speed camera, goverment ATM
Wayne
Sir Postalot
Re: haunted mk3
22 October 2010, 20:25 »
Fault in the wiring, faulty switch or bad earth.
Len
10k hero
Re: haunted mk3
22 October 2010, 21:46 »
Thats usually a Peugeot trait! first time I have heard it on a Mk3!
Check earth first then pull out the bulb holders and see if there is any loose silver stuff or any dirt/moisture
www.sas.org.uk
www.the-ace.org.uk
dubdan90
Re: haunted mk3
24 October 2010, 23:32 »
i would deffinatley go with the bad earth, maybe try a different set of light units just to rule them out, if you still have the problem you will have a wiring issue
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: haunted mk3
25 October 2010, 10:12 »
the earths for rear lights are behind the boot carpets i believe. usually mthough the issue is the plugs on the lights or the bulb holders, the earth points dont usually go wrong as out of the way of any moisture
Len
10k hero
Re: haunted mk3
25 October 2010, 13:30 »
Yes mate thats exactly where the earth is!
www.sas.org.uk
www.the-ace.org.uk
rubjonny
10k hero
Re: haunted mk3
Reply #6 on:
25 October 2010, 13:59 »
coolio ta for zee confirmation len my good chap
Len
10k hero
Re: haunted mk3
Reply #7 on:
25 October 2010, 16:33 »
Only know coz I use it to earth my amp!
www.sas.org.uk
www.the-ace.org.uk
marcford86
Re: haunted mk3
Reply #8 on:
25 October 2010, 22:28 »
As above, i call the above fault disco lights as they flicker/flash in all different manners/ways. i failed a peugeot 306 and mk3 gti the other on there MOT's for the above fault and both times it was a simple earthing issue
nate valve
Re: haunted mk3
Reply #9 on:
29 October 2010, 13:34 »
I got it, it was the seal having perished and there was alot of water and corrosion. screwdriver and tooth pick soon cleared it up till new part arrives today!!!
The garage
haunted mk3
