Author Topic: project neg new wheels page 30  (Read 75648 times)
Offline lemski
  • 16v
Re: project neg
« Reply #200 on: 12 December 2010, 17:23 »
Ahh I see and I'm gettin the seats fully welded up. Using the old subframes. (My mates a sh!t hot welder so he's on the case) as for the harness brace. How thick must it be exactly? Avery thing els is covered.
Offline Bellend
Re: project neg
« Reply #201 on: 12 December 2010, 17:39 »
Have a chat with diamondhell about harnesses though. Apparently they are not as safe as a seatbelt unless you have them strapped onto a harness bar.
While fitting in some random Subaru seats, using the original seat mounts isn't a terrible idea, it will need to be done carefully, to ensure what you're doing is strong enough that it won't collapse in an impact.  How confident are you in your welding?  It has to be properly done, not bird sh*t-stylee rubbish.
Unless you are competent and getting sufficient heat into your welds and penetration making up your own seat-mounts isn't something to be undertaken lightly...... it would be a shame to see some sort of Darwin-esque incident involving your Golf and the deletion of a small number of IQ points from the gene pool.
As for the harnesses, really you need 5/6 point, including a crutch strap and for them to be properly effective they need to be tight enough that you can't move about comfortably in normal road driving.  If you can then I'll wager the set up you have won't retain you any better than a factory 3-point belt.
If you're going to replace your 3-point belts you need a minimum of 3" shoulder straps.  If you go for 4-point harnesses to go with those seats (because there's no crutch strap hole, because they're designed for use with a 3-point belt) then be aware you're at risk of submarining down under the harness, doing a lot of damage to your back especially if it's not properly tightened, because you're 'just driving about on the road'.
You've also got to ask yourself 'what will happen with the shoulder straps in an accident?' because those seats are designed to be used with a 3-point belt, not a harness.  The shoulder straps should really be as short as possible and secured within an angle of 0-10 degrees downwards from your shoulders.  Is the hole in the seat even designed to accept a harness? I doubt it very much, because - here we are again - they're not designed for harness use.
So, you have a single threaded hole on the outside of the car, which is designed to accept the waist strap on the outer side, but the inner seatbelt mount (the clip) is mounted on the seat frame on the original set up, so when you slide the seat forwards and backwards the whole fixed harness will twist across your body and need substantial adjustment to ensure it's correct whenever the seat is moved.
You'll need to weld a spreader plate on the underside of the tunnel (not the inside) to secure the inner waist strap mounts.
Now what of the shoulder straps?  You've got nothing to use in the rear, have you?  The top mounts for the rear seats are miles away and off-centre, so you'll be dragged across in an impact.  The bottom mounts are way outside the maximum 45 degree angle downwards, plus if you use them, on an impact, as the seats aren't designed to take a downwards force on impact the back rest, the harnesses are going to pull down on your spine and crush it - yay back problems for you.  Your only option is to fit a 'proper' harness bar - tubing of the correct diameter across the rear turrets, with appropriate spreader plates to stop it tearing out on an impact.
Even suggesting you could use a strut brace to mount your straps to is utterly laughable.  It's designed to stiffen the car, not take any form of impact.  You'd be a complete moron to ever contemplate using one as a mount.
So, possibly a little more work than you're expecting and something that is not going to be comfortable, or sensible in a day to day car.
You'd be far better off retaining the standard 3-point belt and getting one of these for enthusiastic driving.
Well, you asked.  :grin:
Where all my moneys went.
Offline lemski
  • 16v
Re: project neg
« Reply #202 on: 12 December 2010, 18:45 »
Yeh but ma mates got the seats in his mk2 aswell and there perfect. He binned his in the summer and the seats didn't collaps or owt so I'll get on with it tomorow. :)
Offline Diamond Hell
  • Opinions я Us
Re: project neg
« Reply #203 on: 12 December 2010, 19:04 »
Do your own research.  :wink:
So you've covered off the spreader plates on the inside of the tunnel as well?
Offline lemski
  • 16v
Re: project neg
« Reply #204 on: 12 December 2010, 19:11 »
Well is a spreader plate to space out the harness edges off the runners. Like a washer type thing? And a scafold pole type thickness for harness bar? I can get all that's needed from various people I know. And I though advice was suppose to be given. People have different size harness bars. I just would of liked to know how thick exactly. You could of just said to research it all and not offered any help instead of being a nob about it. Am sure your intentions are ment well but if you didn't want to give advise then you could of just said DH.
  • Opinions я Us
Re: project neg
« Reply #205 on: 12 December 2010, 19:18 »
Go on the attack, why not?
A spreader plate goes inside the tunnel and has the nut welded to it, it spreads the load of the pull from the harness.
NEVER scaffold bar anywhere in your car, ever.
I've given you a bunch of information, but why the hell should I spoon-feed you all of the information you need?  Go learn yourself some understanding yourself.  Look out the MSA's Blue Book for 2011 to understand what you need.  You'll come out the other side wiser which will make it worthwhile, instead of being a knob about it.  :rolleyes:
Offline lemski
  • 16v
Re: project neg
« Reply #206 on: 12 December 2010, 19:20 »
Yeh all I asked for was advise I never said I was ungreatfull. and I will look out for that book. I will scan internet properly for them downloadable book things when am not on phone internet. I've had a bit of a rough day and am just takin it out on people I am sorry for that and thankyou again for the information given.
  • Opinions я Us
Re: project neg
« Reply #207 on: 13 December 2010, 22:00 »
Offline SoundillusioN
Re: project neg
« Reply #208 on: 13 December 2010, 22:28 »
To be fair I wouldn't want to give any more advise tonight after a long helpful response like that... sounds like a feck load of trouble and it's why I am not bothering with harnesses with my new seats for now.
Offline lewis1641
  • stuck in the 90's
Re: project neg
« Reply #209 on: 13 December 2010, 22:33 »
here's your answer i think liam.  it reads that harnesses should be attached to the rollcage and the spec for that tubing is
1.4.1. Specifications of the tubes used:
Minimum Material
Cold Drawn Seamless Carbon Steel
Minimum Yield Strength
350 N/mm2
Minimum Dimensions (Ø in mm)
45 x 2.5 or 50 x 2.0
38 x 2.5 or 40 x 2.0 (For roll cages/bars approved
prior to 1.1.95).
1.4.2. In selecting the steel, attention must be paid to
obtaining good elongation properties and adequate
weldability.
this is obviously for motorsport purposes but at the end of the day if it is good enough for the track its good enough for mummy's little soldier on the road. we just need to figure out what that actually means before walking into a steel supplier and looking like a tool!
