Golf mk3
hardmonkeys
Springs don't fit...
Topic: Springs don't fit... (Read 1046 times)
Jack3559
21 October 2010, 12:48 »
Springs are too wide at the top and keep pinging over the spring caps when I undo the clamps...
Am I doing something wrong or are they just sh!t springs?
Len
10k hero
Re: Springs don't fit...
21 October 2010, 12:56 »
Got them the right way up?
www.sas.org.uk
www.the-ace.org.uk
Jack3559
21 October 2010, 13:01 »
Haha!
Yeah, they are.
Big at the bottom small at the top.
I'm pretty pissed off about it now.
Wayne
Sir Postalot
21 October 2010, 13:14 »
Spring sizes changed, 65mm and 85mm I believe.
DazVR6
mk3 VR6...FEEL THE GRUNT.
21 October 2010, 14:17 »
Had exactly the same problem with my vr when i bought some new Jamex suspension from ebay.
Had to go to the stealers, buy the larger spring plates and fit them, only way to solve this issue.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
21 October 2010, 16:06 »
what top mounts does it have too, if its the earlier ones with the bearing and top mount all in 1 piece you cant fit them to these springs, you'll have to convert to MK3 GTI top mount and large spring plate setup
Jack3559
Reply #6 on:
21 October 2010, 20:32 »
Yeah...
I'm going to need the bigger spring plates.
The rears are nowhere near low enough either, but I really don't want to be sending stuff back to Belgium.
rubjonny
10k hero
Reply #7 on:
22 October 2010, 09:42 »
as well as GTI top mounts + bearings, you need:
1J0 412 341 - MK3 GTI upper spring plate, large size
1H0 412 365 A - threaded bush
N 105 352 01- top nut
Golf mk3
hardmonkeys
