The garage
vw sharan 2.0 tdi 56 reg
Topic: vw sharan 2.0 tdi 56 reg (Read 2916 times)
sharki786
GOT BOOST??
20 October 2010, 19:30 »
having some probs with the locking on this 7 seater. every time i use the fob to close the doors, all doors close apart from the drivers and the diesel cap stays open? when i unlock it from the fob (button) the drivers door will lock its just weird. sometimes the diesel cap will close and sometimes it wont. is there anything i can do to reset everything?
thank you all
sharki
*****MK3 Anniversary*****
*****MK4 GTI T*****
sharki786
GOT BOOST??
Re: vw sharan 2.0 tdi 56 reg
24 October 2010, 15:13 »
anyone?
*****MK4 GTI T*****
sharki786
GOT BOOST??
29 October 2010, 21:28 »
bumpy
*****MK4 GTI T*****
AudiA8Quattro
Forum addict
30 October 2010, 21:09 »
Try VAG com
sharki786
GOT BOOST??
30 October 2010, 22:56 »
will that show up on the vag com about the locks? we going to get that done this week hopefully. cheers mate
*****MK4 GTI T*****
AudiA8Quattro
Forum addict
30 October 2010, 23:03 »
Yes.
The central locking is all electric.
You should get a fault code, or you can test each door lock on measuring blocks.
sharki786
GOT BOOST??
Reply #6 on:
30 October 2010, 23:25 »
its weird, we took the lock out (where the key goes into) from drivers side and connected it to the pas side it worked but when connecting back to the drivers side it still had same prob. thanks for that matey
*****MK4 GTI T*****
AudiA8Quattro
Forum addict
Reply #7 on:
31 October 2010, 11:25 »
Did you take off the door trim and remove the complete unit? sounds like a failed solenoid.
sharki786
GOT BOOST??
Reply #8 on:
31 October 2010, 15:34 »
well took the driver side door card off and took the pull handle off and then the motor, we then connected it to the pas side and it worked fine with the remote. basiclly the motor works fine from the pas door, but when we connect it back to the drivers door it plays about and so will the petrol cap lock, where would the solenoid be? is this the solenoid?
http://cgi.ebay.co.uk/VW-SHARAN-2003-P-S-R-DOOR-LOCK-SOLENOID-/130429199745
this is what we changed over and worked fine from pas door
Last Edit: 31 October 2010, 17:22 by sharki786
*****MK4 GTI T*****
AudiA8Quattro
Forum addict
Reply #9 on:
31 October 2010, 17:46 »
Looks like it, i've only done one on an Audi before. Very similar design i believe.
Can you lock the door using vag com output tests?
Could be wiring to the door, or even central convenience control unit at fault.
The garage
