Author Topic: key out but still running  (Read 896 times)
Offline popleyruss
« on: 20 October 2010, 17:38 »
My  mates just popped over and his mk3 gti 8 valve is not turning off when u take the key out division had to show him how to turn it off just by pulling the coil pack lead off
What could this be ignition switch?
Just plain dubbin
Offline dom
  • Back in a Mk4
Re: key out but still running
« Reply #1 on: 20 October 2010, 21:13 »
Could be the switch, would it not be easier for him to just stall the car rather than pull leads out??  :huh:
Offline popleyruss
« Reply #2 on: 20 October 2010, 23:16 »
True I did say that and he said it will brake haha
Just plain dubbin
« Reply #3 on: 21 October 2010, 09:16 »
are the dash warning lights still on when you cut the car out by pulling coil plug
Offline popleyruss
« Reply #4 on: 21 October 2010, 10:21 »
Yeah sumtimes
Just plain dubbin
« Reply #5 on: 21 October 2010, 10:25 »
look at the ignition switch next. try disconnecting the plug from it to see if car switches off then. if it does, you need a new switch. if it doesnt, you need to check the wiring behind the fusebox, somewhere there is a short from a permanent live feed to an ign live feed
Offline popleyruss
« Reply #6 on: 21 October 2010, 10:30 »
To the rescue again cheers and ill let u no about popping to basingstoke ASAP cheers
Just plain dubbin
