Author Topic: 8v GTi Exhaust help please  (Read 1557 times)
Offline 8vSukhi
« on: 20 October 2010, 13:25 »
Hi,
I've got a couple of genuine VAG exhaust boxes (middle ones) that I've picked up in the past, for my car.
Although they look identical, they have slightly different part numbers.
I tried to fit the one marked 191 119 C to my car and while it fitted straight to the back box, the diameter of the pipe was too big to fit tightly to the pipe running from the front of the car.
The one marked 191 119 AC fitted perfectly.
Is 191 119 C for the 16v cars?
Thanks
Sukhi
Re: 8v GTi Exhaust help please
« Reply #1 on: 20 October 2010, 13:50 »
non of those numbers exist, plus they're too short it should be 6 numbers?
16v is bigger bore front to back so it wont be that
Offline 8vSukhi
« Reply #2 on: 20 October 2010, 16:01 »
Hi,
It's the number that is stamped onto the box.  The original VAG one I removed from the car also had the same number (191 119 AC) stamped into it.
One of them has got a barcode on it but unfortunately half of it's missing.
'16v is bigger bore front to back ' - sorry when you mean front to back, do you mean the entire length is of a bigger bore than the 8v?
Thanks
« Reply #3 on: 20 October 2010, 16:26 »
yep, downpipe back are all 2.25" bore. perhaps to fit that other box you need a double clamp like you get at the front between the downpipe and first silencer
Offline 8vSukhi
« Reply #4 on: 20 October 2010, 19:14 »
Hi,
The bit of the barcode that I can see ends 253 409.
Any ideas?
Thanks
Offline messenjah
« Reply #5 on: 21 October 2010, 08:24 »
253409  means it is a genuine vag middle box
the one with AC stamped on it is for RP RH and GU engines ?
and the one with C stamped on it is for edition one PF and PB engines ?
according to vag cat
