Here you go Snoopy
Remove radiator grille
Remove front bumper cover
– Remove bolts -4-.
– Remove bolts -2- (pointing upwards) on left and right of wheel housing.
– Remove bolts -3- from wheel housing.
– Remove bolts -5- and -6- from underneath.
Further removal is only possible with the help of a second mechanic.
– Pull front bumper cover -1- out of fasteners of guides on left and right of wing -arrows a-.
– With the aid of a second mechanic, pull off front bumper cover -1- parallel -arrows b- from vehicle.
– Disconnect connectors from all electrical components.
Notes and work sequence for parking aid are located in → Electrical system; Rep. Gr.94
Instructions and work specifications for the Park Assist system can be found in → Electrical system; Rep. Gr.94
– Disconnect washer fluid hose connectors (if fitted) → Electrical system; Rep. Gr.92
