Author Topic: Idle Valve 8v GTi  (Read 4198 times)
Offline gti69
Idle Valve 8v GTi
« on: 05 June 2003, 17:11 »
I have just recently had my car on the rolling road and everything was fine apart from my timing being 20 degrees out ???
Also they said that my idle valve was showing signs of wear, can these valves be overhauled or do they need to be replace outright? I have been looking to see how much they are i have seen them for ?164!
If it can't be overhauled, does anybody know where i can get one cheaper????
Thanks
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline Bdub
Re:Idle Valve 8v GTi
« Reply #1 on: 24 June 2003, 15:33 »
The 8V ISV can't be overhauled only cleaned ( with Carb cleaner or simillar ) I got a second hand one from Central Breakers in Derby - 01332 371819. they will probably mail to you.
This sorted mine and have had no further probs. It cost 35 quid though.
Offline gti69
« Reply #2 on: 26 June 2003, 12:17 »
Thanks for the help. I will give them a call.
Offline richandhazel
« Reply #3 on: 26 June 2003, 12:25 »
Info on ISV:-
http://homepage.ntlworld.com/richandhazel1/ISV/index.htm
Not sure if they are the same but here is a good bit of info from an Audi website:-
http://20v.org/engprob.htm#isv
