Author Topic: nitrous/ bottom end rebuild  (Read 1405 times)
Offline benji mk2
  • Soon be christmas!
« on: 31 January 2005, 15:08 »
I have an early MK2 8v GTi engine that I'm going fit into my mk1. It has done 100k but the head was recently rebuilt (its also a GTi engineering 8V PLUS-PAC head conversion) I want to rebuild the bottom end before I put it into the car. Also I'm toying with idea of putting a small nitrous kit onto the car (well why not eh?) What work would people recommend
1) just as a good bottom end rebuild and
2) a bottom end rebuild with nitrous in mind?
I'm a bit unsure on a few points of a bottom end rebuild. I'm an ok mechanic but have no major bottom end experience. If I replace the main bearing for the crank do I need to have the crank re ground or anything? I know that the shells have to be matched up correctly if you remove and then refit them, so what do you do when fitting new ones??
Lots of questions I know but I would be very grateful to anyone that can help.
Ben Confused
Offline davidhawkins_78
  • Valver Bad Boy
Re: nitrous/ bottom end rebuild
« Reply #1 on: 31 January 2005, 16:46 »
I'd be interested on this one too - pretty dam good at everything other than bottom ends!
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Gambit
« Reply #2 on: 31 January 2005, 17:32 »
if your going for a bottom end then it might be an idea to get hold of a 2.0 bottom end and rebuild that
Offline benji mk2
« Reply #3 on: 01 February 2005, 16:38 »
yeah i was thinking of a 1.9 re bore and getting one of the tsr bore and build kits. you get everything you need (pistons con rods bolts etc etc) for just shy of ?600. Unless anyone has a 2.0l bottom end going spare?????
