Author Topic: the buggers stalling now!!!!!  (Read 853 times)
Offline grahamw1604
« on: 19 October 2010, 09:35 »
the girlfriends car has started to stall now.  it has stalled on occasion in the past but has started to be more regular.. she has the gti 8v.  i have been nosing through some of the topics and it seems the usual suspect is a dirty throttle body.  if this is the case, am i better cleaning with carb cleaner while engine running or am i better removing and doing while of the car,  could there be anything else causing the stalling, its not all the time but like i said, it is getting more regular,  girlfriend just told me that it hunts and when the rev drops it stalls so any advice is appreciated
thanks graham
Offline snifferdog
Re: the buggers stalling now!!!!!
« Reply #1 on: 19 October 2010, 11:20 »
Best to take the throttle body off and use carb cleaner. You may need a new gasket when replacing though (?!) Also, I think there is a known relay that can cause the stalling problem, best have a look through the mk3 maintenance section.
Offline grahamw1604
« Reply #2 on: 19 October 2010, 20:42 »
cheers pal
Offline snifferdog
« Reply #3 on: 19 October 2010, 20:44 »
This one may help
http://www.golfgtiforum.co.uk/index.php?topic=101400.0
Or maybe not, cant be arsed to read through it  :grin: :grin:
