Author Topic: Im going to cam my 8v  (Read 2957 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Im going to cam my 8v
« Reply #10 on: 19 October 2010, 20:41 »
If you can do a cam belt you can do a camshaft,  they are simple as far as internals go, Price ranges from £160 to £500  It makes it sound nice, makes it go better but its all about shifting the power,  it doesn't make power as such, it will take for eg.. 10hp from 2000 rpm and give it to 4000 rpm,  depending on the type you fit.   Thats about as much as i know about uprated shafts.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #11 on: 19 October 2010, 20:45 »
I would run a 268, to get the most out of a 272 you need other mods really.
Offline sharki786
  • GOT BOOST??
« Reply #12 on: 19 October 2010, 21:51 »
what other mods wayne?
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #13 on: 19 October 2010, 22:04 »
Better breathing, gas flowed head and a remap or maybe even a bigger valve head.
Offline Khare
  • The bear that khares
« Reply #14 on: 19 October 2010, 22:14 »
It'll be better but not essential. I'd still get the highest spec you can.
Offline sharki786
  • GOT BOOST??
« Reply #15 on: 19 October 2010, 22:34 »
thanks wayne & khare  :wink:
*****MK4 GTI T*****
Offline bored_Welsh_lad
« Reply #16 on: 19 October 2010, 22:36 »
Wayne didn't we have a debate about cams on here and you said they were sh!t in the 8v?? I am pretty sure you did!!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
« Reply #17 on: 19 October 2010, 22:39 »
This was the resulting thread i believe... Again found in the mk3 maint section
http://www.golfgtiforum.co.uk/index.php?topic=129138.20
Bumper Vents :D
« Reply #18 on: 19 October 2010, 23:33 »
Not quite, I am old school and think do the cam last as such plus you were saying the standard cam was only 204 degrees, however with seeing what gains Khare got then it looks a good step.
Hope this clears this up  :smiley:
« Last Edit: 20 October 2010, 09:13 by Wayne »
Offline Rmachines
« Reply #19 on: 21 October 2010, 17:17 »
Cams will always make a difference, but its moving the power not making extra power,   to make extra you need to combine it with others to get the "best of both"   Personally i want my engine to have a bit more up the rev range and the sound of the cam, but not big power.
when they say they add 10hp its taking it from somewhere else from the rev range but who drives arround at low revs ay?
