Author Topic: TUNING The 8v Camshaft Thread..  (Read 72812 times)
Offline axewielder
  • 95 dragon 8v
Re: The Camshaft 8v Information Thread..
« Reply #20 on: 29 September 2009, 23:45 »
ABA american crossflow 8v
Identification
◆ Cam base diameter: a = 34 mm ø
◆ Identification by stamped numbers and letters between inlet and exhaust cams:
Engine code
 ABA▸07.96          ABA 08.96 ▸
Cylinder 1 -arrow I-
 D                            B
Cylinder 3 -arrow II-
 048                            050
Valve timing at 1 mm valve lift
Motorkennbuchstaben
 ABA▸07.96                 ABA08.96▸
Inlet opens ATDC
 6 °                                 1 °
Inlet closes ABDC
 45 °                                37 °
Exhaust opens BBDC
 42 °                               41 °
Exhaust closes BTDC
 4 °                                  5 °
Offline axewielder
  • 95 dragon 8v
« Reply #21 on: 29 September 2009, 23:47 »
still cant get pb but hit me up with any more codes
can get valve dimensions ect tooo
VW BUSH
« Reply #22 on: 30 September 2009, 00:59 »
What part number do you need?
Edit:
Any use
PB uses 026109101G (i think)
« Last Edit: 30 September 2009, 01:06 by VW BUSH »
Offline bored_Welsh_lad
« Reply #23 on: 30 September 2009, 07:56 »
This thread just gets better n better!!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline axewielder
  • 95 dragon 8v
« Reply #24 on: 30 September 2009, 09:05 »
engine code is all i need man, there just isnt the info for the pd+ alot of mk4s
just let me know what your looking for+ill se what i can find
do you guys want the id marks off of the mk3 ones??
VW BUSH
« Reply #25 on: 30 September 2009, 12:59 »
Tell you what i will measure he PB one do the sums and post it when i fit it this weekend :smiley:
Offline aphexvw
Re: INFO The 8v Camshaft Thread..
« Reply #26 on: 24 November 2010, 15:08 »
I know this is old but stumbled from google.
PB according to ECP is part code 026109101G
218/219 @ 1mm and lift is .400
214/214 @ 0.05mm
source = Techtonics cam sheet
So basically the OBDII has a larger lift @ 0.417 but the PB has a longer duration of +4 / +4
« Last Edit: 24 November 2010, 16:25 by aphexvw »
