Author Topic: Fly Wheel  (Read 5075 times)
Offline Paul123
Fly Wheel
« on: 18 October 2010, 08:35 »
My Car is vibrating wheen Idleing is this a sign my fly wheel is on the way out? what millage do they changing at?
Offline asif
Re: Fly Wheel
« Reply #1 on: 18 October 2010, 08:39 »
I hope not cuz my brother replaced mine at 55k now on 79k and mine is vibrating a bit on idle also.
Although I also been told it may be to do with some judder valve been switched off on the remap IIRC.
Has your been mapped mate.
Don;t think there is a mileage when it goes although it's probably 100k onwards.
MK7 GT Bluemotion Tech TDi 150
Offline Paul123
Re: Fly Wheel
« Reply #2 on: 18 October 2010, 08:42 »
No its not been remapped mate, Only does it now and again, its like a vibrating noise rather than the car vibrating
Offline asif
Re: Fly Wheel
« Reply #3 on: 18 October 2010, 08:47 »
Would you explain it as pulsating (SP) as that is the best way I can explain mine.
Offline Paul123
Re: Fly Wheel
« Reply #4 on: 18 October 2010, 09:00 »
Yeh thats sounds the same as mine mate, I took it to the local garage (not a VW Garage) and he couldnt find anything wrong with it. When my fans are turned off it doesnt normally happen
Offline asif
Re: Fly Wheel
« Reply #5 on: 18 October 2010, 09:02 »
I've not got to the bottom of it either and nothing shows up on scans either.
StevePD did advise that it may be something called a release bearing in the clutch region i'm not too techy so can;t explain properly.
But that doesn;t mean that it's that for deffo but a possibility to add to the list of other unfortunately
Offline Paul123
Re: Fly Wheel
« Reply #6 on: 18 October 2010, 09:51 »
It doesnt really bother me it doesnt cause any lost in performance and you cant really hear it outside of the car, I was just worried it might be the flywheel
Offline asif
Re: Fly Wheel
« Reply #7 on: 18 October 2010, 10:02 »
Same sort of thing Steve said that it's something alot of people just put up with.
Is it ok once the car is warmed up?
I gave my car a good run out yesterday and this morning it didn't really do it as much when i first started it, just after about 5 mins into the journey.
Offline asif
Re: Fly Wheel
« Reply #8 on: 18 October 2010, 10:04 »
If you put it in 4th gear and do about 30mph then floor it, if it judders loads then could possibly be the flywheel. Good to test it on your car as it's not been mapped so on standard torque.
Offline Paul123
Re: Fly Wheel
« Reply #9 on: 18 October 2010, 13:49 »
When you say floor it do you mean drop a gear? or just floor it in 4th. Thanks for the advice il try it on the way home later.
