Author Topic: out of interest  (Read 1696 times)
Offline fozziie
  • psn: fozziie
out of interest
« on: 17 October 2010, 15:03 »
does anybody know which bits from a MK3 (engine interior etc etc) can be transplanted into a MK2 shell? because if it works out cheaper for me to buy a MK2 with a fubered engine or whatever than it is to have all the welding etc etc done, then i'll be going down that route.
Re: out of interest
« Reply #1 on: 17 October 2010, 21:33 »
Not much to be honest, if the mk2 is a later car then te engine will swap in easy enough.
Offline fozziie
  • psn: fozziie
Re: out of interest
« Reply #2 on: 17 October 2010, 22:32 »
so id need a G or H reg MK2 if i was going to get a shell yeah? or any MK3
Offline carsforce
Re: out of interest
« Reply #3 on: 17 October 2010, 22:38 »
have a look at mine m8.might b able to sell the shell if u want,just a shame as the car is to good to break
Re: out of interest
« Reply #4 on: 18 October 2010, 10:14 »
what engine is it you have in the mk3? pretty much everything bay side will swap over except the rad, heater matrix fits as do the shocks from all 4 corners, wishbones, hubs etc. wiring loom plugs in if mk2 is 90spec, doesnt if its pre-90. but not always an issue depending what mk3 engine and what mk2 you want to put it into.  fuel tank, pump, filter housign and lines also fit straight on, but may not be required again depending on mk3 engine ansd what mk2 you get to put it into.
manifold and downpipe will fit, get a cat bypass and it'll fit straight onto a mk2 16v exhaust system.  isnt a lot from a mk3 mechanically that doesnt fit tbh, trim obv wont be any use.
rear seats pretty much straight swap, front seats fit using 90spec mk2 front seat bases from any model
Offline Len
Re: out of interest
« Reply #5 on: 18 October 2010, 13:05 »
I thought the welding was just a couple of sills? :huh:
www.sas.org.uk
www.the-ace.org.uk
Offline dom
  • Back in a Mk4
Re: out of interest
« Reply #6 on: 18 October 2010, 13:22 »
+1 i'm struggling to see how transferring the internals of your mk3 into a mk2 shell is going to be easier/cheaper than welding a couple of sills  :undecided:
Offline fozziie
  • psn: fozziie
Re: out of interest
« Reply #7 on: 18 October 2010, 14:05 »
its not just the sills, the guy at the garage hasn't even taken the plastic off the sills yet. its underneath the car, theres a hole just behind the front jacking point and he claims its needing more done under the car aswell, all they can say just now is that the labour for one side alone, based on a quick inspection, is going to be between 2 and 3 hundred quid. And then theres still the other side to do aswell. so factor for twice that. so its looking like 400 quid of welding.
Offline fozziie
  • psn: fozziie
Re: out of interest
« Reply #8 on: 18 October 2010, 14:09 »
and then of course theres the cost of materials for welding, and the front suspension, the tyres arent too much of a problem, i can get them cheap enough, the wheel bearing, the cost of storing the car for a few months while i save the pennies for the welding etc etc. its gonna be far easier to get hold another shell and make one good car from the two.
Offline Len
Re: out of interest
« Reply #9 on: 18 October 2010, 14:51 »
Depends where that hole is. If its inboard of the sill seam, which is the jacking point then yes its a bit more involved but only a plate job.
Have told you on a previous thread what the sills cost.
I really think you should get some more quotes!
I cant believe there is only one garage you can take this to in the Dundee area.
www.sas.org.uk
www.the-ace.org.uk
