Author Topic: mk2 abf conversion  (Read 8400 times)
Offline Diamond Hell
  • Opinions я Us
Re: mk2 abf conversion
« Reply #10 on: 17 October 2010, 16:21 »
and obviously no cat, which helps.
Offline bosco
« Reply #11 on: 17 October 2010, 16:52 »
has anybody done an abf conversion into a 1985 mk2 or any year around that? i just wanna no if there is any reason fo me to buy say a post 1990 mk2 or are they the same. thanks?
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
« Reply #12 on: 17 October 2010, 19:21 »
Later mk2's had a different wiring loom and I believe it makes the conversion easier.
VeeDubGTI16v
« Reply #13 on: 17 October 2010, 19:59 »
i have, but its running kjet meaning it is likely to explode and kill everyone within a 1 mile radius if revved over 6.5k
wiring was pretty easy though, all plugged straight in apart from one of the idle control module wires, a few of the instrument wires and another which i have forgotten which need splicing into the existing loom
Offline bosco
« Reply #14 on: 17 October 2010, 23:11 »
so it should be ok if i get a wiring loom from an 89-92 gti maybe?
1990 mk2 1.6 daily
Offline Neo Badness
  • Feet are for pedals
« Reply #15 on: 18 October 2010, 10:31 »
I've asked loads about this, the general concensus is that it's better to use the mk3 ABF OEM management engine loom spliced into the back of mk2 fuse box. There are how to guides getting it running on Kjet. Just search on here or google ABF conversion :smiley:
« Reply #16 on: 18 October 2010, 10:39 »
if you're doign bodies it doesnt matter what car you get, thewiring will need splicing no matter what.  earlier the better really as they're lighter than the big bumper cars. if going oem managment 90spec makes it easier, but pre-90 isnt too hard really. worst case I can make a conversion loom for you if you dont fancy it? but my fusebox faq covers the pins on fusebox, and i have loads of diagrams which will help you with the conversion
Offline bosco
« Reply #17 on: 18 October 2010, 17:23 »
the early mk2s had a ce1 loom amd the later ones had a ce2b loom though so would i get a later mk2 fusebox and plug the abf into it?
1990 mk2 1.6 daily
Offline danny_p
« Reply #18 on: 18 October 2010, 18:54 »
just replug the loom it's almost as easy as sireing for engine conversion gets
all the VW's have gone bar 1.
« Reply #19 on: 19 October 2010, 10:37 »
aye up to 90 they had ce1 and after that it was ce2. can be a delay between manufacture and being sold so check the hazard switch, best way to know for sure. hazard on dash = ce1, hazard on column = ce2. mk3 golf uses ce2 fusebox as well, hence 99% plug n play.  some bits differ like the wiper motor loom is a lot shorter on mk3, plus some have the lighting loom combined into engine loom. mk2 has seperate lighting loom which you leave in the car when doing engine swap.
