Author Topic: Carb Problem  (Read 1279 times)
Offline sellers
  • Daz Works in Health and Beauty
Carb Problem
« on: 30 January 2005, 18:32 »
hi, i have taken my car into the garage to get its high reving and over fueling problem sorted out, i have asked people what it could be and had a look at it myself and have come to no conclusion
the bloke at the garage says that the wiring to the carb is bodged thats why, and he's only charging me a tenner to fix? does that sound right? also he says he wont charge me if it doesnt fix it?
BTW its a 1.6 driver with the usual pierburg
Can't think of a funy or whitty comment
Offline AudiA8Quattro
Re: Carb Problem
« Reply #1 on: 30 January 2005, 18:44 »
Well you can't really go wrong for a tenner i suppose  :wink:
Offline mk1
Re: Carb Problem
« Reply #2 on: 30 January 2005, 18:46 »
Agree with '6, cant go wrong and he wont charge if it doesn't fix it :smiley:.
Steve.
Re: Carb Problem
« Reply #3 on: 31 January 2005, 10:56 »
It could be yes, there are several electrical bits:
Autochoke heater
Inlet manifold Preheater
Another heater on the front
Idle overrun valve
Temp time valve
The Autochoke and inlet heaters are controlled by the temperature of the engine coolant, in the plastic flange at the front of the block there is a red and grey sender, red is for the autochoke and grey is for the inlet heater.
The heater on the front should get a constant 12v feed, and is earthed through the carb using an earth lead conected between the top of the carb and the rocker cover. The last two control the 3/4 point unit which is responsible for holding the revs up for a couple of seconds when you start the car from cold, which doesn't sound like they are to do with your problem.  You should hear a click from the engine bay when you turn the ignition key though.
But I would say you are likely to have a problem with the inlet manifold coolant channel, a common fault is the o'ring seal degrades and blocks the channel so coolant never reaches the autochoke & waxstat, the carb coolant pipes should get boiling hot when the engine is up to temp!
