Author Topic: high rev's  (Read 1314 times)
Offline sk8boy73
high rev's
« on: 15 October 2010, 18:06 »
Hello people
My 8v has started to idle high!
If you blip the throttle it will settle at 10 thou and then go up to 20thou!
Any ideas?
Cheers john
Offline apie2004
Re: high rev's
« Reply #1 on: 16 October 2010, 09:15 »
Have you got an f1 engine in your car?
Offline apie2004
Re: high rev's
« Reply #2 on: 16 October 2010, 09:17 »
In all seriousness it sounds like an ISV problem, the metallic cylindrical tube on top of the rocker cover. I think you can clean it with carb cleaner but have a search just to make sure I am right.
Offline sk8boy73
Re: high rev's
« Reply #3 on: 16 October 2010, 19:16 »
Yeah hot that a bit wrong!
I'll have a look tomorrow.
Re: high rev's
« Reply #4 on: 18 October 2010, 10:27 »
check the idle switch clicks off and on when you open/shut throttle and the wiring to the throttle body hasnt snapped. make sure throttle shuts all the way to the stop firmly. idle switch is underneath to tricky to get to if you need to adjust it
