Author Topic: BUZZING!!!!!!!!!!!!!!! PLEASE HELP!!!!!!!!!!!!!!  (Read 2134 times)
Offline adams mk2
« on: 15 October 2010, 17:03 »
on my vw golf gti mk2 KR engined i acidently put some ancient fuel in the tank and next time i went to start it had a flat battery so i replaced the battery and still didnt start so i filled the tank up with superunleaded and still didnt start so i was told to replace the fuel pump so i have done that aswell and still no starting so i have put some easy start down the air intake and it fires but as soon as up stop it stops firing. i have also notist a buzzing coming from the top of the engine which has a pipe to the airfilter PLEASE PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ANY IDEAS PLEASE REPLY
Offline popleyruss
Re: BUZZING!!!!!!!!!!!!!!! PLEASE HELP!!!!!!!!!!!!!!
« Reply #1 on: 15 October 2010, 17:12 »
Have u checks the fuelpumps got power going to it? Also is the relay  knackerd
Just plain dubbin
Offline adams mk2
« Reply #2 on: 15 October 2010, 17:17 »
how could i check the fuel pump got power????
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #3 on: 15 October 2010, 19:16 »
Buzzing is your ISV, which is normal.
Offline adams mk2
« Reply #4 on: 15 October 2010, 20:30 »
ok cheers just wundering if it had enything to do with it
« Reply #5 on: 15 October 2010, 21:13 »
Yep, normal
Is the fuel pump priming / running all ok.
Offline adams mk2
« Reply #6 on: 15 October 2010, 21:20 »
i carnt here it doin anything :/
« Reply #7 on: 15 October 2010, 21:30 »
Could be a blown fuel pump relay
Offline adams mk2
« Reply #8 on: 15 October 2010, 21:55 »
is it easy to replace?? and how much is it goin to cost???
« Reply #9 on: 18 October 2010, 10:21 »
pull the relay and bridge the 2 large pins. if pump runs its relay, ecu isnt powering up or relay trigger wiring is damaged. have you checked the fuse? have a read of my fusebox faq page 2 it has relay & fuse locations for both pre and post-90 mk2 fuseboxes
