Author Topic: I'm confused, Speed sensor, Vehicle or Engine?  (Read 1037 times)
Offline garethcab
« on: 15 October 2010, 10:05 »
Hi all,
I'm just about to pop to Europarts and get a engine sensor but it dawned on me that i'm not 100% sure it is that.
I have this read from the ECU;
Address 01: Engine
   Controller: 037 906 025 A
   Component: SIMOS 4S           1823
   Coding: 00000
   Shop #: WSC 00000
1 Fault Found:
00625 - Vehicle Speed Signal
            16-00 - Signal Outside Specifications
Readiness: N/A
Anyone got any ideas?
Thanks
Offline dom
  • Back in a Mk4
Re: I'm confused, Speed sensor, Vehicle or Engine?
« Reply #1 on: 15 October 2010, 10:22 »
Did you scan it with the engine off? If so try again with the engine running and see if you still get it  :smiley:
Offline garethcab
« Reply #2 on: 15 October 2010, 10:54 »
Yes, engine off.
Ok, will give that a go. I kinda assumed it should be off when you run diags.
