Author Topic: ecu query  (Read 1384 times)
Offline harlemex
ecu query
« on: 14 October 2010, 23:21 »
I was wondering if an the ady ecu in my car will run an agg engine. ie if i put an agg lump in my car will the current ecu(ady) run it okay??
Offline Khare
  • The bear that khares
Re: ecu query
« Reply #1 on: 14 October 2010, 23:26 »
As long as ecu code is the same it will be fine. I ran an agg ecu in my old. Ady.
Offline harlemex
Re: ecu query
« Reply #2 on: 14 October 2010, 23:32 »
Ahh okay. I recently put an engine in mine which was meant to be the ady like my old engine. I looked on the timing case after i fitted it  :lipsrsealed: and it says agg. So I wondered whether it was an ady with a agg cover on it. (If you get what i mean)  :huh:
Re: ecu query
« Reply #3 on: 14 October 2010, 23:34 »
AGG is different managment set up so would run better on the correct ecu, however I believe you would need to do some work to get it run.
Offline harlemex
Re: ecu query
« Reply #4 on: 14 October 2010, 23:42 »
Cheers. Maybe the engine I have put in is actually the ady in that case. Not sure about any running issues as such cos im running it in at the mo so havent thoroughly tested it. Is there any way I can find the code other than the timing case?
Re: ecu query
« Reply #5 on: 14 October 2010, 23:43 »
Should be stamped in the block.
Offline harlemex
Re: ecu query
« Reply #6 on: 14 October 2010, 23:44 »
Okay, thanx. I will investigate tomorrow.  :smiley:
Re: ecu query
« Reply #7 on: 14 October 2010, 23:45 »
Post it up when / if you find it.  :smiley:
