Author Topic: running abit lean  (Read 2951 times)
Offline sharki786
  • GOT BOOST??
running abit lean
« on: 14 October 2010, 18:45 »
my mk3 gti 8v AGG is running abit lean how could that be adjusted?? or it cant?
thanks all
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Khare
  • The bear that khares
Re: running abit lean
« Reply #1 on: 14 October 2010, 18:54 »
What makes you think its running lean mate?
« Reply #2 on: 14 October 2010, 23:46 »
thanks all
As Khare said what makes you think it is running lean, no way of adjusting it I believe.
« Reply #3 on: 15 October 2010, 11:12 »
as above it cant be adjusted, all ecu controlled. main suspects if mixture is wrong is ecu temp sensor and/or lambda probe. as above again, what are the symptoms  :grin:
Offline DubSociety
« Reply #4 on: 15 October 2010, 11:33 »
If its a bit juicy on fuel, the only way you can sort it out is:
A. Service it:- Plugs, Oil/Filter, Air Filter,
AND/OR
B. Turn on the trip meter, find out how many miles you do with a tenners worth of fuel for example, and then keep an eye on the trip counter so you know how many miles you got left before you have to visit Mr BP or Mrs Esso again. <-- this way you'll stop doing extra miles, and just generally be more careful with driving around for no reason ...
« Last Edit: 15 October 2010, 11:35 by DubSociety »
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 15 October 2010, 13:14 »
well it smells lean (you can smell the petrol( like yesterday it was coldish and i started the car and there was steam but it smelt petroly, it does under 100miles on £20 vpower. im getting about under 25mpg its 8v agg gti i do give it abit, also a friend of mine has a snapon diag and it blatently came up showing lean
« Last Edit: 15 October 2010, 13:16 by sharki786 »
*****MK4 GTI T*****
Offline harlemex
« Reply #6 on: 15 October 2010, 13:26 »
What is your temperature gauge reading?
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 15 October 2010, 13:30 »
70-90 depending if im stuck in trafgic or driving khare did say its thermo stat. is there a way of doing the termo without taking timing belt of?? wayne did say that you remove the alternator but someone said you you cant do it like that as the water pump gets stuck? or have i got it wrong?
*****MK4 GTI T*****
Offline harlemex
« Reply #8 on: 15 October 2010, 13:37 »
Yes you can do it without touching the cam belt. And you do need to remove the alternator and slacken the power steering pump and push out the way abit. All for easier access to get to the flange on the waterpump. Tis a tad awkward but still do-able with some patience. I think it could be why you are using to much fuel. The car will run rich if the engine is running cool.  :smiley:
Offline dom
  • Back in a Mk4
« Reply #9 on: 15 October 2010, 13:59 »
+1 sounds like your culprit!
