Author Topic: mk2 1.3  (Read 1791 times)
Offline bosco
mk2 1.3
« on: 14 October 2010, 12:14 »
hi guys was just wondering iv been offered an 1985 mk2 1.3 cheap and it is an incredibly sound body. i wanna slap an abf in it but dunno if its the right model for it? would i be better off looking for an old gti to do this or is the 1.3 mainly the same? it also has a 4 speed would that be hard to change to another gearbox? thanks guys
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline The Mighty Elvi
  • I'm better than you today.
Re: mk2 1.3
« Reply #1 on: 14 October 2010, 12:23 »
Can do, but you'd need the loom and fuel pumps.  You'd need the gear box as well.
Offline apie2004
Re: mk2 1.3
« Reply #2 on: 14 October 2010, 12:24 »
Would you need a GTi rear beam as well?
Offline Ben Lessani
Re: mk2 1.3
« Reply #3 on: 14 October 2010, 12:51 »
If the body is good, then why not! You can pinch almost all of the other bits from the MK3 (gearbox/loom/engine). You'd be better buying a whole MK3 (4 stud ideally), then you can pinch its beam, bones, brakes.
jamrock
Re: mk2 1.3
« Reply #4 on: 14 October 2010, 12:54 »
IIRC a 90 spec car would be easier to convert,  :undecided:
Re: mk2 1.3
« Reply #5 on: 14 October 2010, 12:57 »
Why not run the ABF on carbs.
You will still need to uprate brakes etc.
Offline bosco
Re: mk2 1.3
« Reply #6 on: 14 October 2010, 13:01 »
yeah the brakes would be the first thing to do cause i hope to use it for a bit of racing and the occasional drag. what brakes would be best? thanks
1990 mk2 1.6 daily
Re: mk2 1.3
« Reply #7 on: 14 October 2010, 13:44 »
I also have a 1.3 B reg sitting in my garage. Keep us posted on what you do to yours and I might do the same to mine.
Jonathan.
Re: mk2 1.3
« Reply #8 on: 14 October 2010, 14:31 »
with it being early the fusebox is different to mk3, you could fit a complete 90spec mk2 car loom or just splice pre-90 plugs onto the abf loom. its not particularly difficult but i can do conversion looms if you arnt keen./ you dont HAVE to swap the beam but fitting one with a roll bar in from a gti is a nice upgrade. you could just bolt on an aftermarket arb though which would be just as good. no rear discs but you dont really need em drums work just fine.  up front need to change pretty much everything bar subframe and wishbones, even brake servo needs swapping for a 9" one.  nothing thats particularly difficult, and if you get a donor car as above makes things easier.  complete 16v would be a nice place to start would give you everything you need including fuel setup, though would need to go 5 stud if you use its complete running gear. depends if you're bothered about that or not!
abf -> mk2 is a bolt in thing using all off the shelf vw parts if you buy the right  bits, only thing that isnt direct swap is the wiring loom
Offline bosco
Re: mk2 1.3
« Reply #9 on: 14 October 2010, 16:22 »
thanks guys hopefully il get the car and get cracking on things when i get time during college.
1990 mk2 1.6 daily
