Author Topic: just a quicky about brakes  (Read 1334 times)
Offline Cory
« on: 14 October 2010, 11:59 »
hi guys. i have a driver, and im just wondering if disc's + pads and a big wider on gti's?
and if so will they fit on my car? also, wil 256mm fit under 14'' wheels?
many thanks  :smiley:
Offline rob.043
Re: just a quicky about brakes
« Reply #1 on: 14 October 2010, 14:19 »
iirc, the driver has solid discs 239mm dia, with wider pads, and an 8v GTi (early 16v) has 239mm dia vented discs with slimmer pads. So if you get GTi discs and pads, they will fit, as the calipers are the same. I think.
I had 14's steels over my 256 brakes last winter. So should be fine
Offline Khare
  • The bear that khares
« Reply #2 on: 14 October 2010, 14:22 »
You can buy gti 8v discs and pads and they will fit straight to your 239mm driver install. It's the same apart from a vented disc on the 8v gti and slimmer pads as rob said above.
« Reply #3 on: 14 October 2010, 14:33 »
check the calipers you have now, if they have VWII stamped on em you can fit vented gti discs & pads straight on. if they dont you need to change the calipers and 1 of the mounting bolts too. i cant remember if the 1.6 got VWII calipers or not off top of me head
Offline Cory
« Reply #4 on: 14 October 2010, 18:19 »
Thanks for the info guys, super helpful. Anyone know cheapest placed to buy them from? Or part numbers? Dnt have Internet at my uni flat yet =(
Offline rob.043
« Reply #5 on: 15 October 2010, 10:56 »
I think I got my last lot from GSF, and im very happy with the performance of them (no fade issues, and respond well when they get warm). I dont know who to reccomend tho, as im sure the quality will vary between manufacturers, and you want good brake parts! So it may not be advisable to buy the cheapest available if the brand has little or no reputation. GSF, Euro Car Parts, and VW spares are perhaps the usual suspects to check, maybe even good old e-bay too.
