Author Topic: headlight adjuster  (Read 14524 times)
Offline sharki786
  • GOT BOOST??
Re: headlight adjuster
« Reply #80 on: 15 October 2010, 21:46 »
toopay: did you have to change the full loom from the switch to the lights or just connect it up in the engine bay??
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Jack3559
« Reply #81 on: 15 October 2010, 23:24 »
Do the adjusters work if you swap to vento lights?
« Reply #82 on: 15 October 2010, 23:25 »
Yes as some Vento headlamps have the motors.
Offline Toopay_MkIII_GT
« Reply #83 on: 16 October 2010, 11:14 »
just connected it all up from engine loom, didnt have to do anything within the dash
and yes the adjusters work with vento lights
Offline harlemex
« Reply #84 on: 16 October 2010, 12:27 »
Hahaha the thing is nobody really cares apart from you.
looks like you are wrong pal.
Offline harlemex
« Reply #85 on: 16 October 2010, 12:31 »
There seems to be a a little confused info about wiring. I dont know about vento lights, but I kinow for starters you need the correct headlamp switch with adjusters on it. There is an extra connector needed to go into this. As for the motors, you will need a light loom with them on(I think) similar to your usual loom that has the large multiplug above the radiator. You will not need a new dash loom if you have a gti or similar as the wiring already exists.
« Reply #86 on: 16 October 2010, 15:06 »
^^ correct
Offline sharki786
  • GOT BOOST??
« Reply #87 on: 16 October 2010, 22:38 »
mine is an 8v gti anniversary so should just be plug and play??
*****MK4 GTI T*****
« Reply #88 on: 17 October 2010, 20:49 »
yep  :smiley:
Offline marky-gee
« Reply #89 on: 07 January 2011, 19:33 »
so
Do you need anything else , as i have a set of hella's and i also have adjusters as standard ?
Im looking at the diagram as you need some sort of plastic caps for the ball on the motor ?
1997 GOLF GTI 2.0 (8v)
