Author Topic: 8v trouble  (Read 875 times)
Offline reg
8v trouble
« on: 10 October 2010, 17:43 »
ive had my golf for about 6 month now. when i first got it when i set off on a morning it would cut out when i was around 200 meters down the road when i got to a junction.
it only happens when im slowing down and the clutch is in, everytime it would bump start then run fine and then be ok for the rest of the day.
i cleaned the throttle body with carb cleaner and the golf ran smooth and with no problems (apart from the flat spot at 2k rpm) for around 6 month. now its started doing it more frequently but again only when slowing down and pressing in the clutch.
i recently fitted coilovers and its dropped pretty low, i dont know if this is the cause as its mostly doing it on wet days so im not sure if the spray on the road is affecting anything??
ive read posts about cleaning the maf but then heard it could cause problems later on???
any advise on what this could be?
Offline jimmyb
Re: 8v trouble
« Reply #1 on: 10 October 2010, 17:55 »
Offline sharki786
  • GOT BOOST??
Re: 8v trouble
« Reply #2 on: 10 October 2010, 18:00 »
if its cutting out when it rains then its seems like theres an electric prob (coilpack) do a search on here and see what you find
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Khare
  • The bear that khares
Re: 8v trouble
« Reply #3 on: 10 October 2010, 18:29 »
Classic ECU relay symptoms  :wink:
Offline reg
Re: 8v trouble
« Reply #4 on: 21 October 2010, 18:43 »
hi cheers for the posts and sorry for late reply, ill get some of that ordered and give it a try.
