Author Topic: I have a smelly VAG  (Read 1734 times)
Offline jpgti
I have a smelly VAG
« on: 08 October 2010, 20:21 »
There is nothing worse than a smelly vag.  :shocked:
Anyway i noticed the other day that i have water coming into the gti from somewhere, the floor is soaking wet. Has anyone else had this and have they sourced the location of the leak.Advice and opinions appreciated.
Offline christomk3gti
Re: I have a smelly VAG
« Reply #1 on: 08 October 2010, 20:31 »
Sunroof drain holes blocked??
Or try removing the scuttle panel below the windscreen and clear the drain holes.
Or seals on the doors could be leaking??
Christo.
Black 8v GTI............. Whats a Waffle Valve?
Offline AlexMozza
« Reply #2 on: 08 October 2010, 20:42 »
Ok, I clicked this link for all the wrong reasons.....
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 08 October 2010, 21:20 »
Or it could be really bad and the heater matrix could be shagged !!!!!  As said though check the drainage holes under the scuttle panel and the sunroof (if you have one).  Best of luck      Cheers
Offline harlemex
« Reply #4 on: 08 October 2010, 21:27 »
so your vag is not just smelly, its also very wet.. :grin:
« Reply #5 on: 08 October 2010, 21:38 »
+1 heater matrix could be in trouble.
Offline AlexMozza
« Reply #6 on: 08 October 2010, 21:43 »
EPIC lol
2001 Satria GTi
Formula 3 Mechanic
« Reply #7 on: 08 October 2010, 21:54 »
Forgot about the heater matrix....
Check your Expansion Tank and see if its loosing water. IF not then your heater matrix will be fine.
Christo
Offline AlexMozza
« Reply #8 on: 08 October 2010, 21:54 »
How does nobody find this thread funny
2001 Satria GTi
Formula 3 Mechanic
« Reply #9 on: 08 October 2010, 21:55 »
We maybe more mature  :wink:
oj  :grin:  :grin:
