Author Topic: When I start my Golf up  (Read 1040 times)
Offline mk2Ben
« on: 28 January 2005, 01:31 »
Its a 1.8 GL 87
From cold I start it up and it starts first turn of the key, but it finds it hard to tick over. :s..
Afer about 3-6 mins it ticks over at 2000rpm., seems to me like the choke is comiing on to late ?.
Or somthing else ?.
After about 10 mins it sits lovley just under 1k.
How do I sort this small problem out?.  :sad:
Thanks very much in advanced.
Give me time, cant wait for my first V-Dub show in m OWN Golf.
Re: When I start my Golf up
« Reply #1 on: 28 January 2005, 11:04 »
Sounds like the autochoke isn't switching off fast enough, its the cylinder thing at the right side with 2 coolant hoses and an electrical connection.  Check the plug gets 12v when the engine is cold, if not check the red temp sensor in the plastic flange at the front of the block passes current when the engine is cold.
I think the problem is more likely to be the coolant channel o'ring in the inlet manifold has degraded and blocked the flow of coolant to the carb.  This is a common fault on old dubs, did it on mine and its been perfect ever since  :smiley:
Let me know if you have any other carb issues as I've probably had the same problem with mine  :grin:
Do you live anywhere near Bracknell?  If so I'll be happy to take a look for ya  :smiley:
