Author Topic: Steering rack please help!!  (Read 1443 times)
Offline Ardz83
« on: 08 October 2010, 19:04 »
Hi guys. My mate is currently stuck on his driveway trying to fit a mk2 gti rack into his 1.3 mk2. Will the collum piece from the 1.3 fit on the gti spline?
He has been on it all day but cant get it to go on due to the angle of the collum knuckle but i think its a different size. He is now taking the dash out to undo the steering collum.
Hope this makes sense.
Dan
Re: Steering rack please help!!
« Reply #1 on: 08 October 2010, 19:33 »
pas and manual racks use a different uj, so if you're upgrading to pas that'll be why! you also need a different uj boot
Offline Ardz83
« Reply #2 on: 08 October 2010, 19:43 »
Sorry they are both manual racks.
« Reply #3 on: 08 October 2010, 19:54 »
if both manual then they'll bolt up fine, just a case of patience and maybe some harsh language  :grin:
note the uj will only slide on 1 way as the rack spline has a missing tooth where the split in the uj fits if that makes sence, also you need to remove the clamp bolt from the uj otherwise it wont go on
Offline Ardz83
« Reply #4 on: 08 October 2010, 20:27 »
Ahh right so it will only fit in one way?
« Reply #5 on: 11 October 2010, 11:18 »
aye, if you look carefully at the spline on the rack you'll note it has a tooth or 2 missing, then if you look at the uj theres a slit in it so it can open and close when bolt loosened/tightened. the missing tooth fit into that slit :)
