Golf mk3
hardmonkeys
intermittent knock in the right hand side front end
Topic: intermittent knock in the right hand side front end (Read 1252 times)
quincey
08 October 2010, 12:42 »
hey y'all,
i have a strange knocking sound coming from the front end of my 3 door MK3. it sounds like (but isnt) something is hanging off and bumping along the road. the motor purrs like a kitten so its nothing to do with that. the noise starts after about half an hour of running and seems to be worse when i turn or veer to the right. i have checked in the search section but cant find anything similar. any suggestions? i took it to a local garage but as there was no knocking when he took it for a drive, he could offer no help.
your thoughts would be appreciated.
shanco73
Re: intermittent knock in the right hand side front end
08 October 2010, 13:29 »
take it in to a car park and try turning on full lock, one way then the other see if you can hear the clunk, could be a CV joint, would expect you to hear the noise all the time though, gotta be worth a try.
AlexMozza
Here all the time
08 October 2010, 19:48 »
Sounds like the CV. Thats what mine om my Celica was like, jack the car up and turn the wheel by hand, if its the CV you should be able to feel a bit of resistance.
Easy fix if it is that
2001 Satria GTi
Mini 25 Special Edition 1984 998
Formula 3 Mechanic
Wayne
Sir Postalot
08 October 2010, 21:46 »
Seems strange it only happens when you warm it up, maybe a gearbox problem
christomk3gti
08 October 2010, 21:58 »
or a driveshaft problem.
I'd go for the CV Joint tho.
Black 8v GTI............. Whats a Waffle Valve?
Wayne
Sir Postalot
08 October 2010, 22:08 »
Quote from: christomk3gti on 08 October 2010, 21:58
Yes but they tend to knock all the time when they are failing.
christomk3gti
Reply #6 on:
08 October 2010, 22:15 »
I agree but not always.
CV Joint is the likely suspect.
sharki786
GOT BOOST??
Reply #7 on:
08 October 2010, 23:25 »
could be your gearbox mount. have a check to see if there is any oil around the mount it would be like a brown colour
*****MK3 Anniversary*****
*****MK4 GTI T*****
Golf mk3
hardmonkeys
