Author Topic: 8v vs 16v engine mounts  (Read 2443 times)
Offline GolfGTI8v
« on: 08 October 2010, 09:36 »
I'm about to buy 16v mounts all round for my agu conversion however ive not long ago replaced my 8v items for new oem stuff.
So what's the difference between the 8v & 16v engine mounts?  16v stronger?  can anyone recommend aftermarket upgrades ?  as im guessing the price vs. OEM stuff aint too different
Thanks  :smug:
Offline Khare
  • The bear that khares
Re: 8v vs 16v engine mounts
« Reply #1 on: 08 October 2010, 09:59 »
There all the same mate.
Offline GolfGTI8v
« Reply #2 on: 08 October 2010, 10:08 »
Really?   Excellent news!!  lots of info on the net recommending 16v mounts with the conversion.  so great, some money saved there.
My next question,   VR6 clutch is recommend,  is the OEM item good enough or aftermarket jobbies better? looking to go around 250hp now !
also are the 8v/ 16v flywheels the same i.e can i use my 8v flywheel on my agu lump with a VR6 clutch kit?
thanks  :smiley:
Offline Khare
« Reply #3 on: 08 October 2010, 10:12 »
8v and 16v flywheels are different. The 1.8T's clutch can be uprated to a single mass flywheel using the G60 flywheel and VR6 clutch I think, there's plenty of info around the forum especially in the mk4 section. As far as I know for clutch quality, an OEM one will handle the standard 150hp with no problems, but if you're looking at 250hp you want something aftermarket. Sachs do one of the best clutches out there.
Offline GolfGTI8v
« Reply #4 on: 08 October 2010, 11:17 »
thanks mate,  i will have a search around !
Offline AlanD
  • MK5 2.0T 16v
« Reply #5 on: 08 October 2010, 11:17 »
8v has more low down torque.
Offline Khare
« Reply #6 on: 08 October 2010, 11:24 »
8v crew
16v crew
Offline AlanD
  • MK5 2.0T 16v
« Reply #7 on: 08 October 2010, 11:25 »
:D :D :D :D :D
Just thought Id stick my nose in.
As you were gents.
« Reply #8 on: 08 October 2010, 11:27 »
Yep and I still prefer a well sorted 8v unless it is a mk1.
Offline Khare
« Reply #9 on: 08 October 2010, 11:32 »
Here we go again  :grin: :grin: :grin:
