Author Topic: MK4 Clutch Pedal  (Read 11245 times)
Offline Geordie
MK4 Clutch Pedal
« on: 07 October 2010, 16:06 »
My clutch pedal has just gone on my car, anybody know how expensive it will be to buy a new one and get fitted
Offline Rhyso
Offline Dan_GTI
  • GTi addict formally known as yoof
Re: MK4 Clutch Pedal
« Reply #2 on: 07 October 2010, 18:08 »
about £25 for an original replacement, fit it yourself using the guides on here or garage will take about an hour to fit
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline Geordie
« Reply #3 on: 07 October 2010, 20:13 »
Thanks for the info
Ive been told its a dealer only part! or do you think i could get the pedal from another parts place?
Offline Rhyso
« Reply #4 on: 07 October 2010, 20:25 »
Thanks for the info
Dealer only part
Offline smokey gti
« Reply #5 on: 07 October 2010, 20:30 »
I got one from a breaker on ebay 10 quid plus 5 quid postage. hardest thing about fitting was the spring but a little tip is to close the spring in a vice and ty wrap it put it in place and cut them carefully. Another thing is if you found the little plate that breaks off the peddle and you can weld, you can weld it back on i've done it with my old one and kept it as a spare
mk 1 gti cab mk 4 18T fun in the sun and fun in the rain
Offline GTMonster
« Reply #6 on: 07 October 2010, 20:32 »
I had this problem in my last MK4 Golf. I was happily driving along and suddenly my foot went to the floor while pressing the clutch on a gear change. Cost me about £150 to have it repaired as VW advised that they had to do some welding behind the clutch and replace some mechancs behind the peddle.
Offline smokey gti
« Reply #7 on: 07 October 2010, 20:46 »
robbing barstewards the mechanics they mention is a bit of plastic and the welding is a little metal plate about 10mm by 20mm took me about a hour to fit mine and weld my old one total cost 15 quid
Offline Steve_PD
« Reply #8 on: 07 October 2010, 21:50 »
did you have a creaking sound coming from your clutch pedal before it broke?
Offline Geordie
« Reply #9 on: 07 October 2010, 21:54 »
Nah it didnt, was no warning at all, one minute it was fine then it just went
the aa bloke said it was the black metal bit that had snapped off which was the cause, he did a tempory fix for me to get home
